1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: asyn driver problem running Linux 3.8.13 with arm processor
To: "'Eric Norum'" <[email protected]>
Cc: "'epics'" <[email protected]>
Date: Fri, 7 Feb 2014 16:46:12 -0000
That's just a simple array
int data[2];
and it is the same size defined in the ISR.
Jim
> -----Original Message-----
> From: Eric Norum [mailto:[email protected]]
> Sent: 07 February 2014 16:43
> To: Jim Chen
> Cc: Mark Rivers; epics
> Subject: Re: asyn driver problem running Linux 3.8.13 with arm processor
> What's the declaration of 'data' in your example?
> On Feb 7, 2014, at 8:38 AM, Jim Chen <[email protected]>
> wrote:
> > Mark and Eric,
> > I might have pointed to the wrong place. I have deleted everything for
> > the message queue task as simple as below and it runs fine the first
> > time but segfault immediately when it waits again:
> > while(1) {
> >        /* Wait for event from interrupt routine */
> > printf("====before\n");
> >       epicsMessageQueueReceive(intMsgQId, data, sizeof(data));
> > printf("====queue responsed\n"); }
> > The debug printout:
> > ====before
> > ==== queue responsed
> > ====before
> > Segmentation fault
> > This looks like something wrong with the message queue? Anyway I will
> > do more tests...
> > Jim
> Eric Norum
> [email protected]
asyn driver problem running Linux 3.8.13 with arm processor Jim Chen
RE: asyn driver problem running Linux 3.8.13 with arm processor Mark Rivers
RE: asyn driver problem running Linux 3.8.13 with arm processor Jim Chen
Re: asyn driver problem running Linux 3.8.13 with arm processor Eric Norum
Prev: Re: asyn driver problem running Linux 3.8.13 with arm processor Eric Norum
Next: WG: Re: motorRecord on linux-arm Jens . Eden
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: asyn driver problem running Linux 3.8.13 with arm processor Andrew Johnson
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
