Shudder!
If you absolutely have to test for endianness w/o external help
then let the compiler figure it out, e.g., like this:
int
is_little_endian()
const union {
unsigned short us;
unsigned char uc[2];
} tester = { us: 1 };
return !! tester.uc[0];
rather than getting lost in a maze of #ifdefs
FWIW: gcc will optimize all of this away and just use the appropriate result
which is known at compile time.
- Till
On 02/07/2014 07:21 AM, [email protected] wrote:
I recently tried to run a motor on a Raspberry Pi and found that the DMOV
field would never
return to 1 after the move completed. The reason is, that the following
cpu-architecture
switch in motor.h doesn't have an entry for armv6
#if defined(_WIN32) || defined(_M_IX86) || defined(_X86_)
#define LSB_First (TRUE) /* LSB is packed first. */
#elif defined(__i386__) || defined(_armv4l_) || defined(_X86_64_) ||
defined(__APPLE__)
#elif defined(i386)
#elif defined(sparc) || defined(m68k) || defined(powerpc)
#define MSB_First (TRUE) /* MSB is packed first. */
#elif (CPU == PPC604) || (CPU == PPC603) || (CPU == PPC85XX) || (CPU ==
MC68040) || (CPU == PPC32)
#else
#error: unknown bit order!
#endif
Since (CPU == PPC604) is true for all cases where CPU is undefined, the
arm compiler did not
fall through to the error message in the else case.
I suggest to remove the switch and replace the occurrence of MSB_First
with the EPICS
provided endianness switch:
+#include <epicsEndian.h>
-#ifdef MSB_First
+#if (EPICS_BYTE_ORDER == EPICS_ENDIAN_BIG)
Jens
- motorRecord on linux-arm Jens . Eden
Re: motorRecord on linux-arm Ron Sluiter
RE: asyn driver problem running Linux 3.8.13 with arm processor Jim Chen
<2014>
Re: motorRecord on linux-arm Till Straumann
WG: Re: motorRecord on linux-arm Jens . Eden
<2014>
