1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: motorRecord on linux-arm
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 7 Feb 2014 15:32:32 +0000
This has been an ongoing headache every time a new EPICS architecture appears, and if it works to use epicsEndian.h then that should definitely be done.
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Friday, February 07, 2014 9:21 AM
To: [email protected]
Subject: motorRecord on linux-arm
I recently tried to run a motor on a Raspberry Pi and found that the DMOV
field would never
return to 1 after the move completed. The reason is, that the following
cpu-architecture
switch in motor.h doesn't have an entry for armv6
#if defined(_WIN32) || defined(_M_IX86) || defined(_X86_)
    #define LSB_First (TRUE)  /* LSB is packed first. */
#elif defined(__i386__) || defined(_armv4l_) || defined(_X86_64_) ||
defined(__APPLE__)
#elif defined(i386)
#elif defined(sparc) || defined(m68k) || defined(powerpc)
    #define MSB_First (TRUE)  /* MSB is packed first. */
#elif (CPU == PPC604) || (CPU == PPC603) || (CPU == PPC85XX) || (CPU ==
MC68040) || (CPU == PPC32)
#else
    #error: unknown bit order!
#endif
Since (CPU == PPC604) is true for all cases where CPU is undefined, the
arm compiler did not
fall through to the error message in the else case.
I suggest to remove the switch and replace the occurrence of  MSB_First
with the EPICS
provided endianness switch:
+#include <epicsEndian.h>
-#ifdef MSB_First
+#if (EPICS_BYTE_ORDER == EPICS_ENDIAN_BIG)
Jens
motorRecord on linux-arm Jens . Eden
Prev: RE: asyn driver problem running Linux 3.8.13 with arm processor Jim Chen
Next: RE: asyn driver problem running Linux 3.8.13 with arm processor Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: motorRecord on linux-arm Jens . Eden
Next: Re: motorRecord on linux-arm Ron Sluiter
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
