1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED]
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Wed, 5 Feb 2014 17:23:50 +0000
Hi Damien,
Thank you for the patch. I have included it in an updated release 2-3 at http://controls.diamond.ac.uk/downloads/support/ethercat/
I paste below the release notes, also included in the tar file. Note that since release 2-0 we are using a patched etherlab library and there are links to the patch.
Ronaldo
* R3.14.11 releases
These version are unmodified, except for the asyn dependency:
| Release | release date | asyn dependency |
|     1-9 | <2013-04-30> |            4-17 |
|    1-10 | <2013-08-21> |            4-17 |
|   1-9-1 | <2013-09-05> |            4-19 |
|    1-11 | <2013-10-04> |            4-21 |
* R3.14.12.3 releases
Up to release 2-2, these are releases from the 'rhel6' branch in subversion.
 From release 2-3 these are releases from 'trunk'
** Release 2-3 05/02/14
   Add documentation related to generic ADC.
   Include patch by Damien Lynch.
** Release 2-2 29/10/13
   Create asyn parameter to describe each slave
   Modified scaling to improve support of 24-bit ADCs
   Modified templates for EP3204-0002 and EP3314-0002 to show values
   in deg C
** Release 2-1 19/07/13
   Modifications in iocbuilder support
** Release 2-0 11/07/13
   Release prepared for RHEL6 systems
   uses patched ethercat library
   http://lists.etherlab.org/pipermail/etherlab-dev/2013/000316.html
   http://lists.etherlab.org/pipermail/etherlab-dev/attachments/20130702/7d75709f/attachment-0001.obj
> -----Original Message-----
> From: LYNCH, Damien [mailto:[email protected]]
> Sent: 22 January 2014 00:53
> To: Jon Nielsen; [email protected]
> [SEC=UNCLASSIFIED]
> Hi Jon,
> Change is to ethercat-1-5-3/ethercatApp/scannerSrc/scanner.c:
> diff scanner.c.original scanner.c
> 162a163,167
> >             // gets reply to LRW frame sent last cycle
> >             // from network card buffer
> >             ecrt_master_receive(master);
> >             ecrt_domain_process(domain);
> 170,173d174
> <             // gets reply to LRW frame sent last cycle
> <             // from network card buffer
> <             ecrt_master_receive(master);
> <             ecrt_domain_process(domain);
> Thanks,
> Damien
> From: Jon Nielsen [mailto:[email protected]]
> Sent: Wednesday, 22 January 2014 11:31 AM
> To: [email protected]
> Cc: LYNCH, Damien
> Subject: Re: DLS EtherCAT scanner and unmatched datagrams
> [SEC=UNCLASSIFIED]
> Hi Damien,
> > Have any DLS EtherCAT module users noticed messages like the
> following in their log?
> > Dec 16 15:31:57 (none) kernel: [17651.934011] EtherCAT WARNING 0:
> 2000 datagrams UNMATCHED!
> > Dec 16 15:31:58 (none) kernel: [17652.934010] EtherCAT WARNING 0:
> > Dec 16 15:31:59 (none) kernel: [17653.934010] EtherCAT WARNING 0:
> Yes I have.  I have a fairly basic system running (Linux, EtherLab,
> r8169, DLS ethercat) and those messages are continuous as long as the
> scanner is running.  I had been meaning to look into it, but since the
> ethercat communications were working fine I figured it was a low
> priority.  I'd be happy to test out your changes if you'd like
> independent verification.  The system is currently running but the
> hardware it's connected to is not being used for anything important for
> a little while.  Cheers,
> Jon
> Jon Nielsen <[email protected]>
> Research School of Astronomy and Astrophysics The Australian National
> University
> Ph: +61 2 6125 8901
DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] LYNCH, Damien
Re: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] Jon Nielsen
RE: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] LYNCH, Damien
Prev: Re: aSub and "user defined structures" ? Andrew Johnson
Next: stdout/stderr buffering on Windows freddie.akeroyd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] LYNCH, Damien
Next: SNL monitor and pvPutComplete Pearson, Matthew R.
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
