From what I can see TPRO is only ever
tested zero/non-zero.
$ grep -w tpro src/db*/*
src/db/dbAccess.c: unsigned char
tpro=precord->tpro;
src/db/dbAccess.c: if (tpro)
src/db/dbAccess.c: if (precord->tpro)
On 01/31/2014 09:27 AM, Dudley, David wrote:
I’m looking through the Documentation on "Fields common to all
record types", and I see that TPRO is defined as:
which seems to imply that the only valid contents are 0 or
1.
I see that TPRO is defined as a UCHAR, in the section
earlier, so I am wondering…..
I need to print varied amounts of information on a record as
it’s being processed, during a debugging session, so can I
plan on using values assigned in TPRO -other- than just 0
and 1 (2,3….) to vary the amount of information printed by
the device driver.
Unless this is a problem, can the definition of that field
be adjusted to state that numbers greater than 0 print
information on the record each time it is processed?
Later-
David Dudley
- Re: TPRO Field Definition Andrew Johnson
- TPRO Field Definition Dudley, David
Question on How to add a new breakpoint table Goff, Steven J
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
