if you look at the first line of your st.cmd, you will see it is referencing the myexample interpreter with path that appears in the error message
So either (1) the path is incorrect or (2) you haven't copied the binary file myexample from your host to your target hardware
Building EPICS/asyn/etc on TS7xxx has been done before.
So you are almost there. Good luck!
Emmanuel
Date: Thu, 30 Jan 2014 10:10:01 +0500
Subject: Cross compilation for linux-arm on target SBC (TS-7300)
[email protected]To:
[email protected]I build IOC for target SBC with linux-arm and copy only Application folder to SBC . When I run .st.cmd I got error
bash: ./st.cmd: ../../bin/linux-arm/myexample: bad interpreter: No such file or directory
Please some one help me?
