1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Command to print out dynamically assigned TCP port
Date: Wed, 29 Jan 2014 13:32:11 -0800
Hello,
   If I start up multiple IOC’s on the same linux server, the IOC’s that start up later use a dynamically assigned TCP port.
>>> cas warning: Configured TCP port was unavailable.
>>> cas warning: Using dynamically assigned TCP port 33470,
  Just curious, is there an EPICS IOC shell command that prints out/displays this port?
Murali
Re: Command to print out dynamically assigned TCP port Andrew Johnson
RE: Command to print out dynamically assigned TCP port Emmanuel Mayssat
Prev: Re: epicsTime::strftime Andrew Johnson
Next: Re: Command to print out dynamically assigned TCP port Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: EDM XY Graph Trace N Field Alan Greer
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
