Subject: |
Re: Binding an IOC to a single network interface |
Ralph Lange <[email protected]> |
Cc: |
EPICS Tech-Talk <[email protected]> |
Date: |
Wed, 29 Jan 2014 10:15:55 +0100 |
On 28.01.2014 23:28, J. Lewis Muir wrote:
On 1/22/14, 8:30 AM, [email protected] wrote:
we are looking to run a set of IOCs that bind channel access to just
the loopback interface on the computer; however I saw from the 3.14
docs that EPICS_CAS_INTF_ADDR_LIST is not currently implemented in the
iocCore CA Server. I had a look at the code in base/src/rsrv and the
attached diff (against 3.14.12.2) seems to work for us with:
EPICS_CAS_INTF_ADDR_LIST=127.0.0.1
EPICS_CAS_BEACON_ADDR_LIST=127.255.255.255
I was just wondering if these additions are sufficient, or have I
missed something elsewhere that either needs changing too or might
cause issues later on?
Freddie
Hi, Andrew.
Have you had a chance to consider the patch sent by Freddie? You seem
open to reviewing and accepting such a patch in the following Tech-Talk
post:
http://www.aps.anl.gov/epics/tech-talk/2013/msg01493.php
I haven't looked at the patch, but the ability to specify the addresses
on which the IOC CA server listens has been a feature I've wished for
for a long time.
Thanks!
Lewis
My 2cts...
At first glance, this patch looks fine and should cover almost all use
cases. That feature has been on the wish list for a long time, I know.
However, I would prefer a slightly more elaborate implementation that
makes the server side environment variables work the same on both CAS
and rsrv. (This will also minimize the necessary changes in the
documentation.)
But, again, I would say for nearly all real-world use cases applying
this patch will do.
Cheers,
~Ralph
- RE: Binding an IOC to a single network interface Hill, Jeff
- Re: Binding an IOC to a single network interface Andrew Johnson
- Binding an IOC to a single network interface freddie.akeroyd
- Re: Binding an IOC to a single network interface J. Lewis Muir
EDM XY Graph Trace N Field Alan Greer
RE: EPICS driver for CAEN NIM8304 or N1471 tom.cobb
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
