1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: App build Error : menu not found
To: Sud Roy <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 25 Jan 2014 14:35:41 +0000
Does gmrtasynInclude.dbd contain the line
include "base.dbd"
If not, I would add it right at the beginning.
Sometimes, when recovering from a .dbd related make problem, you have to start fresh.
I'd do "make clean uninstall" in gmrtasyn_new.
Tim
From: [email protected] [[email protected]] on behalf of Sud Roy [[email protected]]
Sent: Saturday, January 25, 2014 2:03 AM
To: [email protected]
Subject: App build Error : menu not found
Hi Everyone,
I am unable to fix this build error .
Error on specific lines and specified .dbd files are standard ones which comes with the package.
I am using EPICS base 3.14.12.3 and asyn4-22 packages.
(complete build output with error highlighted in bold-blue)
[gmrt@01hw341679 gmrtasyn_new]$ make
make -C ./configure install
make[1]: Entering directory `/home/gmrt/EPICS/gmrtasyn_new/configure'
perl /home/gmrt/EPICS/base-3.14.12.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
make[2]: Entering directory `/home/gmrt/EPICS/gmrtasyn_new/configure/O.linux-x86_64'
perl /home/gmrt/EPICS/base-3.14.12.3/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/home/gmrt/EPICS/gmrtasyn_new/configure/O.linux-x86_64'
make[1]: Leaving directory `/home/gmrt/EPICS/gmrtasyn_new/configure'
make -C ./gmrtasynApp install
make[1]: Entering directory `/home/gmrt/EPICS/gmrtasyn_new/gmrtasynApp'
make -C ./src install
make[2]: Entering directory `/home/gmrt/EPICS/gmrtasyn_new/gmrtasynApp/src'
perl /home/gmrt/EPICS/base-3.14.12.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory `/home/gmrt/EPICS/gmrtasyn_new/gmrtasynApp/src/O.linux-x86_64'
echo "../O.Common/gmrtasyn.dbd : ../Makefile" >> gmrtasyn.dbd.d
Expanding dbd
/home/gmrt/EPICS/base-3.14.12.3/bin/linux-x86_64/dbExpand  -I. -I.. -I../O.Common -I../../../dbd -I/home/gmrt/EPICS/base-3.14.12.3/dbd -I/home/gmrt/EPICS/base-3.14.12.3/support/asyn4-22/dbd -o gmrtasyn.dbd ../gmrtasynInclude.dbd
Error: menu not found
    at or before ")" in path "/home/gmrt/EPICS/base-3.14.12.3/dbd"  file "dbCommon.dbd" line 32
 in path "/home/gmrt/EPICS/base-3.14.12.3/support/asyn4-22/dbd"  file "asynRecord.dbd" line 116
 in path "/home/gmrt/EPICS/base-3.14.12.3/support/asyn4-22/dbd"  file "asyn.dbd" line 9
 in file "../gmrtasynInclude.dbd" line 1
Error: syntax error
   dbExpand: Input errors, no output generated
make[3]: *** [../O.Common/gmrtasyn.dbd] Error 1
make[3]: Leaving directory `/home/gmrt/EPICS/gmrtasyn_new/gmrtasynApp/src/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/home/gmrt/EPICS/gmrtasyn_new/gmrtasynApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/home/gmrt/EPICS/gmrtasyn_new/gmrtasynApp'
make: *** [gmrtasynApp.install] Error 2
Thank you.
Best regards,
Sudeep Roy
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
SOLVED - App build Error : menu not found Sud Roy
Prev: App build Error : menu not found Sud Roy
Next: Re: Build problem of EPICS R3.14.12 (.../ExtUtils/xsubpp not found) Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: SOLVED - App build Error : menu not found Sud Roy
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
