Hi Mark,
On 01/23/2014 06:26 AM, Mark Davis wrote:
> Despite several "make clean", "make realclean", "make rebuild", etc
> commands issued at numerous levels in the tree (and even some manual
> deletions of files that still weren't being wiped or replaced), somehow
> I missed the fact that things (including, apparently asyn) were NOT
> recompiled, and I didn't discover that until I added some diagnostic
> printf's to the code (after which everything worked fine, because that
> DID cause it to recompile).
In the future you should try 'make clean uninstall' or 'make distclean'
to ensure that every built and installed object gets removed; none of
the other targets that you tried will delete the include, bin or lib
directories.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- asyn lock issue? Mark Davis
- Re: asyn lock issue? Mark Davis
RE: SNL monitor and pvPutComplete Mooney, Tim M.
Help with MEDM. Diego Henrique Dorta
<2014>
CAJ and EPICS_CA_AUTO_ADDR_LIST Konrad, Martin
<2014>
