1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED]
Date: Wed, 22 Jan 2014 11:31:16 +1100
Hi Damien,
> Have any DLS EtherCAT module users noticed messages like the following in their log?
> Dec 16 15:31:57 (none) kernel: [17651.934011] EtherCAT WARNING 0: 2000 datagrams UNMATCHED!
> Dec 16 15:31:58 (none) kernel: [17652.934010] EtherCAT WARNING 0: 2000 datagrams UNMATCHED!
> Dec 16 15:31:59 (none) kernel: [17653.934010] EtherCAT WARNING 0: 2000 datagrams UNMATCHED!
Yes I have.  I have a fairly basic system running (Linux, EtherLab, r8169, DLS ethercat) and those messages are continuous as long as the scanner is running.  I had been meaning to look into it, but since the ethercat communications were working fine I figured it was a low priority.  I'd be happy to test out your changes if you'd like independent verification.  The system is currently running but the hardware it's connected to is not being used for anything important for a little while.  Cheers,
Jon
Jon Nielsen <[email protected]>
Research School of Astronomy and Astrophysics
The Australian National University
Ph: +61 2 6125 8901
RE: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] LYNCH, Damien
Prev: SNL monitor and pvPutComplete Pearson, Matthew R.
Next: RE: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] LYNCH, Damien
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] LYNCH, Damien
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
