1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: PV for both input AND output
To: Mark Rivers <[email protected]>, "'Matteo Pardi'" <[email protected]>, EPICS mailing list <[email protected]>
Date: Thu, 16 Jan 2014 11:44:35 -0800
> > You showed me an example about an asynchronous record, but what if I have a synchronous one?
> There is nothing in my example that assumes an asynchronous record. It is using the "asyn" device support, but that works with both asynchronous and synchronous records.
In fact, the proposed solution has nothing to do with asyn.
It will also work with your custom drivers as long as the PVs in the epics database are reading and writing correctly.
Emmanuel
PV for both input AND output Matteo Pardi
RE: PV for both input AND output Mark Rivers
Re: PV for both input AND output Matteo Pardi
Prev: RE: PV for both input AND output Emmanuel Mayssat
Next: RE: A call to 'assert(capacity != 0)' by thread‏ Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: PV for both input AND output Mark Rivers
Next: Re: PV for both input AND output Matteo Pardi
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
