Dear Ganesh, One quick response, you are facing problem due to not getting perl module. make -s runtests not able to find/get 'More.pm' Perl module which is required in seq-2.1.16/test/compiler/make_test_lib.pm (use Test::More;).
It may be in /usr/share/perl/5.14.2/Test/More.pm or refer document how to download and install perl modules. Please check your perl version.
I could ran the test using seq-2.1.15 and seq-2.1.16, hence it is not intrinsic problem with sequencer.
Another thing probably keep Library path to <your installation path>/base-3.14.12.3/lib/linux-x86_64 area, make will search perl module in default areas.
Regards, Jitendra On 16 January 2014 15:54, Ganesh Jangir <[email protected]> wrote:
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
