1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Sequencer Installation error
To: [email protected]
Date: Thu, 16 Jan 2014 15:54:33 +0530
Dear All,
This is regarding the installation of Sequencer on Linux Fedora 19
I am able to "make" sequencer and run the Demo Test and EPICS sequencer example without any failure.
But when i tried with "make -s runtests" i got following error log.
Is there any problem with installation or its with the runtest. How to short it out.
Thank you
Regards
Ganesh
[GMRT@01HW183138 seq]$ make -s runtests
snc_test.t .. Can't locate Test/More.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at snc_test.t line 5.
BEGIN failed--compilation aborted at snc_test.t line 5.
snc_test.t .. Dubious, test returned 2 (wstat 512, 0x200)
No subtests run
Test Summary Report
snc_test.t (Wstat: 512 Tests: 0 Failed: 0)
  Non-zero exit status: 2
  Parse errors: No plan found in TAP output
Files=1, Tests=0,  0 wallclock secs ( 0.02 usr +  0.01 sys =  0.03 CPU)
Result: FAIL
Failed 1/1 test programs. 0/0 subtests failed.
array.t ................ ok
assign.t ............... ok
change.t ............... ok
commaOperator.t ........ ok
local.t ................ ok
opttVar.t .............. ok
pvSync.t ............... Starting iocInit
pvSync.t ............... ok
safeModeNotAssigned.t .. ok
safeMonitor.t .......... ok
userfunc.t ............. Starting iocInit
userfunc.t ............. ok
userfuncEf.t ........... ok
bittypes.t ............. Starting iocInit
bittypes.t ............. ok
evflag.t ............... Starting iocInit
evflag.t ............... ok
monitorEvflag.t ........ Starting iocInit
monitorEvflag.t ........ ok
pvGet.t ................ Starting iocInit
pvGet.t ................ ok
pvGetAsync.t ........... Starting iocInit
pvGetAsync.t ........... ok
pvPutAsync.t ........... Starting iocInit
pvPutAsync.t ........... ok
reassign.t ............. Starting iocInit
reassign.t ............. ok
norace.t ............... Starting iocInit
norace.t ............... ok
bittypesIoc.t .......... Starting iocInit
bittypesIoc.t .......... 1/?
Thanks and Regards
Ganesh Jangir
Date: 12/26/2013 05:45PM
Dear All,
I am tiring to sequencer of my  Linux Machine
I am following the step mention in sequencer User Guide 2.1.16(the latest one)
Following variable are defined EPICS_BASE, EPICS_HOST_ARCH, LD_LIB_PATH already in epics.
During the the make command the compilation goes in to infinite loop..
make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc/O.linux-x86_64'
../../../bin/linux-x86_64/lemon o=. ../snl.lem
3 parsing conflicts.
s -b -o lexer.c ../snl.re
make[3]: s: Command not found
make[3]: [lexer.c] Error 127 (ignored)
make[3]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc/O.linux-x86_64'
. runs endless
ALSO when i tried to run make -s runtests.
 It again goes in to
[GMRT@01HW183138 seq-snapshot-2013-12-19]$ make -s runtests
: runs endless
Below is complete log.
Please help.
_________________________________________________________________________-
make -C ./configure install
make[1]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/configure'
perl /home/GMRT/Desktop/epics/base-3.14.12.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
make[2]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/configure/O.linux-x86_64'
perl /home/GMRT/Desktop/epics/base-3.14.12.3/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/configure/O.linux-x86_64'
make[1]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/configure'
make -C ./src install
make[1]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src'
make -C ./pv install
make[2]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/pv'
perl /home/GMRT/Desktop/epics/base-3.14.12.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/pv/O.linux-x86_64'
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -DPVCA  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include       ../pvNew.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -DPVCA  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include       ../pv.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -DPVCA  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include       ../pvCa.cc
/usr/bin/ar -rc   libpv.a        pvNew.o pv.o pvCa.o
/usr/bin/ranlib libpv.a
/usr/bin/g++ -o libpv.so -shared -fPIC -Wl,-hlibpv.so -L/home/GMRT/Desktop/epics/base-3.14.12.3/lib/linux-x86_64 -Wl,-rpath,/home/GMRT/Desktop/epics/base-3.14.12.3/lib/linux-x86_64       -m64               pvNew.o pv.o pvCa.o    -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libpv.so
Installing library ../../../lib/linux-x86_64/libpv.a
make[3]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/pv/O.linux-x86_64'
make[2]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/pv'
make -C ./seq install
make[2]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/seq'
mkdir O.Common
make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/seq/O.linux-x86_64'
perl ../seq_release.pl 2.1.16 > ../O.Common/seq_release.h
Installing generated generic include file ../../../include/seq_release.h
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include       ../seq_main.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include       ../seq_task.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include       ../seq_ca.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include       ../seq_if.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include       ../seq_mac.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include       ../seq_prog.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include       ../seq_qry.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include       ../seq_cmd.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include       ../seq_queue.c
/usr/bin/ar -rc   libseq.a        seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o
/usr/bin/ranlib libseq.a
/usr/bin/g++ -o libseq.so -shared -fPIC -Wl,-hlibseq.so -L/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/lib/linux-x86_64 -L/home/GMRT/Desktop/epics/base-3.14.12.3/lib/linux-x86_64 -Wl,-rpath,/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/lib/linux-x86_64 -Wl,-rpath,/home/GMRT/Desktop/epics/base-3.14.12.3/lib/linux-x86_64       -m64               seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o    -lpv -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libseq.so
Installing library ../../../lib/linux-x86_64/libseq.a
make[3]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/seq/O.linux-x86_64'
make[2]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/seq'
make -C ./lemon install
make[2]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/lemon'
mkdir O.Common
make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/lemon/O.linux-x86_64'
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include       ../lemon.c
/usr/bin/g++ -o lemon          -m64               lemon.o
Installing created file ../../../bin/linux-x86_64/lemon
make[3]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/lemon/O.linux-x86_64'
make[2]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/lemon'
make -C ./dev install
make[2]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/dev'
mkdir O.Common
make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/dev/O.linux-x86_64'
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include     -I../../../src/seq   ../devSequencer.c
/usr/bin/ar -rc   libseqDev.a         devSequencer.o
/usr/bin/ranlib libseqDev.a
/usr/bin/g++ -o libseqDev.so -shared -fPIC -Wl,-hlibseqDev.so -L/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/lib/linux-x86_64 -L/home/GMRT/Desktop/epics/base-3.14.12.3/lib/linux-x86_64 -Wl,-rpath,/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/lib/linux-x86_64 -Wl,-rpath,/home/GMRT/Desktop/epics/base-3.14.12.3/lib/linux-x86_64       -m64                devSequencer.o   -lseq -lpv -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libseqDev.so
Installing library ../../../lib/linux-x86_64/libseqDev.a
make[3]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/dev/O.linux-x86_64'
make[2]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/dev'
make -C ./snc install
make[2]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc'
mkdir O.Common
Infinite loop
Thanks and Regards
Ganesh Jangir
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
Re: Sequencer Installation error Jitendra Kodilkar
Prev: Re:Re: Failed to install ISR 류수
Next: Re: Sequencer Installation error Jitendra Kodilkar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Sequencer Installation error Benjamin Franksen
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
