1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Failed to install ISR
To: 류수 <[email protected]>
Cc: [email protected]
Date: Wed, 15 Jan 2014 21:50:25 -0500
Could you add some debug code to vxworksDevPCIConnectInterrupt() to
determine what number is actually passed to INUM_TO_IVEC() in
CallPciIntConnect()?  Also, can you say if a PCI interrupt translation
table is provided for your BSP, and if so, is it is large enough to
include interrupt 80?
http://epics.hg.sourceforge.net/hgweb/epics/devlib2/file/8fabcca118fe/pciApp/os/vxWorks/devLibPCIOSD.c#l145
On 01/15/14 21:02, 류수 wrote:
> I changed devlib2 to the development version but it still give me same
> message.
>     ------------ 원본 메일 내용 ------------
>     *보낸 사람 :* "Michael Davidsaver"<[email protected]>
>     *받는 사람 :* "류수" <[email protected]>
>     *참      조 :* [email protected]
>     *메일 제목 :* Re: Failed to install ISR
>     *보낸 날짜 :* Wed, 15 Jan 2014 19:23:14 -0500
>     On 01/15/2014 06:48 PM, 류수 wrote:
>>     I am using devlib2-2.4 and mrfioc2-2.0.1
>     Can you try with the development version of devlib2?  There have
>     been some changes since 2.4 which might be relevant to your problem.
>     $ hg clone http://epics.hg.sourceforge.net/hgweb/epics/devlib2/
>>         *받는 사람 :* [email protected]
>>         *보낸 날짜 :* Wed, 15 Jan 2014 10:47:56 -0500
>>         What versions of mrfioc2 and devlib2 are you using?
>>         On 01/15/2014 10:25 AM, 류수 wrote:
>>>         Hi,
>>>         I am in trouble to initialize PMC-EVR using mrfioc2.
>>>         The PMC-EVR is attached to MV6100 which runs vxWorks 6.9.
>>>         The message says that "Failed to install ISR" so it seems
>>>         that driver can't connect interrupt handler
>>>         to the PCI interrupt, but I don't know how to fix.
>>>         Would you help me out ?
>>>         Regards,
>>>         Soo
>>>         cd "epics/modules/mrfioc2"
>>>         value = 0 = 0x0
>>>         ld < bin/vxWorks-ppc604/mrf.munch
>>>         value = 38203712 = 0x246f140 = '@'
>>>         dbLoadDatabase("dbd/mrf.dbd")
>>>         value = 0 = 0x0
>>>         mrf_registerRecordDeviceDriver(pdbbase)
>>>         value = 0 = 0x0
>>>         dbLoadRecords("db/iocAdminVxWorks.db", "IOC=mrftest")
>>>         Can't register 'system' command -- no command interpreter
>>>         available.
>>>         value = 0 = 0x0
>>>         mrmEvrSetupPCI("PMC1",2,4,0)
>>>         Device PMC1  2:4.0
>>>         Using IRQ 80
>>>         PMC Out FP:3 FPUNIV:0 RB:0 IFP:1
>>>         PMC1 shuting down... complete
>>>         value = 0 = 0x0
>>>         dbLoadRecords("db/evr-pmc-230.db","SYS=PMC, D=PMC:1,
>>>         EVR=PMC1")FWVersion 0x1100000
>>>         6
>>>         Found version 6
>>>         Wvalue = 0 = 0x0
Re: Failed to install ISR Johnson, Andrew N.
Re:Re: Failed to install ISR 류수
Prev: Re:Re: Failed to install ISR 류수
Next: Re: Failed to install ISR Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
