I have an asynPortDriver module I wrote that is currently running fine
on an a VME create running RTEMS on a MVME3100 board. Development and
testing was done on a Linux SIOC using EPICS version R.3.14.9 without
any problems (although it had to be removed from our base config for
that version because the 4.21 version of the asyn module used caused
problems for other modules).
I now have a project that will require the in-house module (and asyn4-21
or later) to run on a a soft IOC running a newer version of EPICS and I
am having problems. In particular, the asynManager appears to be
getting a lock and never releasing it.
Current environment:
asyn version: 4.21
EPICS base version: 3.14.12.2
OS: 3.2.0-57-generic-pae #87-Ubuntu SMP Tue Nov 12 21:57:43 UTC
2013 i686 i686 i386 GNU/Linux
Below is a trace of the relevant portions of the IOC startup. I added
indentation to indicate the operations surrounded by locks. The problem
appears to be that asynManager never releases one of the locks. The end
result is (not too surprising) that the first attempt to write a value
to any of the records linked to the asynPortDriver-based module after
IOC initialization effectively locks up the asyn driver.
Has anyone ever run in to this before? Any idea what could cause this?
#===== Setup for simulated FastCounter device (running on eowyn test
IOC)=====
drvAsynIPPortConfigure("simFCdev", "192.168.4.28:3333 udp", 0, 0, 1)
asynSetTraceMask("simFCdev", 0, 0xFF)
asynSetTraceIOMask("simFCdev", 0, 0xFF)
#===== initialize in-house asynPortDriver-derived module =====
devFastCounterConfig("simFC", "simFCdev", 1000)
=== devFastCounter::devFastCounter: 'simFC' connected to 'simFCdev' ===
asynSetTraceMask("simFC", 0, 0xff)
2014/01/13 11:16:14.015 simFC asynManager::queueLockPort locking port
2014/01/13 11:16:14.015 asynPortDriver:readInt32: function=5, value=0
2014/01/13 11:16:14.015 asynInt32SyncIO read: 0
2014/01/13 11:16:14.015 simFC queueUnlockPort
2014/01/13 11:16:14.015 asynPortDriver:drvUserCreate:
drvInfo=SEQS_PER_GROUP, index=4
2014/01/13 11:16:14.015 asynPortDriver:readInt32: function=4, value=10
2014/01/13 11:16:14.015 asynInt32SyncIO read: 10
drvInfo=COUNT_TIMES, index=9
drvInfo=COUNT_VALUES, index=8
port(<--- never released)
drvInfo=ACQUIRE, index=0
2014/01/13 11:16:14.015 simFC -1 registerInterruptUser
2014/01/13 11:16:14.015 asynPortDriver:readInt32: function=0, value=0
2014/01/13 11:16:14.015 FastCount:TimePerCount_Read
devAsynFloat64::getIoIntInfo registering interrupt
devAsynFloat64::getIoIntInfo created ring buffer, size=10
2014/01/13 11:16:14.015 FastCount:TimePerSeq_Read
2014/01/13 11:18:10.965 simFC queueRequest synchronous
- Re: asyn lock issue? Mark Davis
Re: Failed to install ISR Michael Davidsaver
CAJ and EPICS_CA_AUTO_ADDR_LIST Konrad, Martin
<2014>
<2014>
