1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: EPICS 3.14.12.4 base with vxWorks-6.9 compile error for the ppc604_long target
To: "'[email protected]'" <[email protected]>
Date: Fri, 10 Jan 2014 10:31:34 -0600
I encounter an error while building an EPICS 3.14.12.4 base with vxWorks-6.9 for the case of CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc604_long, see error messages below. Same problem observed for the case of CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc604. EPICS base builds with no errors for the case of CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc603.
The differences in the ccppc cross compiler args are:
-mcpu=604 -fno-implicit-fp -mlongcall
-mcpu=603
Any suggestions?
Oleg Makarov
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc -c -DCPU=PPC604 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/fdmgr/fdmgr.cpp ../../../src/libCom/fdmgr/fdmgr.cpp: In member function 'virtual epicsTimerNotify::expireStatus timerForOldFdmgr::expire(const epicsTime&)': ../../../src/libCom/fdmgr/fdmgr.cpp:154: error: unable to find a register to spill in class 'FLOAT_REGS'
../../../src/libCom/fdmgr/fdmgr.cpp:154: error: this is the insn:
(insn:HI 16 15 17 2 ../../../src/libCom/fdmgr/fdmgr.cpp:153 (set (reg:DF 126 [ D.11745.delay ])
        (mem/s/c:DF (plus:SI (reg/f:SI 113 sfp)
(const_int 8 [0x8])) [15 D.11745.delay+0 S8 A64])) 336 {*movdf_hardfloat32} (expr_list:REG_EQUIV (mem/s/c:DF (plus:SI (reg/f:SI 113 sfp)
        (nil)))
../../../src/libCom/fdmgr/fdmgr.cpp:154: confused by earlier errors, bailing out
make[3]: *** [fdmgr.o] Error 1
make[3]: Leaving directory `/usr/local/epics_local/base-3.14.12.4/src/libCom/O.vxWorks-ppc604_long'
make[2]: *** [install.vxWorks-ppc604_long] Error 2
make[2]: Leaving directory `/usr/local/epics_local/base-3.14.12.4/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/usr/local/epics_local/base-3.14.12.4/src'
make: *** [src.install] Error 2
Re: EPICS 3.14.12.4 base with vxWorks-6.9 compile error for the ppc604_long target Andrew Johnson
Prev: Re: VLANS designing,Geographical vs functional? Konrad, Martin
Next: Re: EPICS 3.14.12.4 base with vxWorks-6.9 compile error for the ppc604_long target Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Sequencer Installation error Benjamin Franksen
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
