1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Increasing scan rate to 10 kHz
To: [email protected]
Date: Wed, 08 Jan 2014 18:11:35 +0100
I did a quick test on my MVME 5100 vxWorks 5.5 system.
1. increasing sysCklRate to 5000 (maximum that vxWorks lets me do)
-> CPU load went up from 2.0% to 2.6%
2. add a ".0002 second" scan rate
-> CPU load went up to 7.3%
3. put some records on the scan:
 ai with "Soft Timestamp" support
 calc to get time interval
 calc to get maximum interval
-> CPU load went up to 27.0%
DZ:TIMEDIFF 0.000200033 sec
DZ:TIMEDIFF 0.000399947 sec
DZ:TIMEDIFF 0.000199914 sec
DZ:TIMEDIFF 0.000400066 sec
After boot:
DZ:MAXTIMEDIFF 0.021000028 sec
After reset to 0 and and some wait:
DZ:MAXTIMEDIFF 0.000400066 sec
DZ:MAXTIMEDIFF 0.000600100 sec
Suddenly after some minutes:
DZ:MAXTIMEDIFF 0.002032518 sec
This does not look very promising.
(DB is attached.)
Dirk
On 08.01.2014 17:20, Till Straumann wrote:
On 01/07/2014 02:19 PM, Andrew Johnson wrote:
Periodic scans are quite complicated, since they rely on the
underlying operating system to implement a delay timer and reschedule
the scan thread after the specific delay has elapsed. Most OSs don't
provide high accuracy delay scheduling, so I don't expect we will ever
be able to run periodic scan threads at 10KHz. - Andrew
As a matter of fact I don't think that 10kHz periodic scans are a big
problem for something like RTEMS
or linux (with RT_PREEMPT) on a reasonably fast CPU.
I just used a simple 'clock_nanosleep' based loop (based on code by
windriver, modified by myself)
which does something like
while ( 1 ) {
     /* get current time */
       clock_gettime( CLOCK_MONOTONIC, &wakeup );
     /* compute wakeup time 100us from now   */
       timespec_add_100us( &wakeup );
     /* sleep until wakeup time      */
       clock_nanosleep( CLOCK_MONOTONIC, TIMER_ABSTIME, &wakeup, NULL );
     /* see when we actually woke up */
       clock_gettime( CLOCK_MONOTONIC, &now );
     /* missed = now - wakeup        */
       timespec_diff( &missed, &now, &wakeup );
     compute_statistics( &missed );
for a bunch of threads (using the SCHED_FIFO scheduler).
On my laptop (vanilla kernel, no RT_PREEMPT) I observe worst-case
'missed' deadline of several milli-seconds
but even on that system the running average is between 5us..50us.
On a kernel patched with RT_PREEMPT I get a worst-case missed deadline
by ~10us (average around 3-4us)
after running for a few minutes (on a not heavily loaded intel core
i7-2655LE, 2.2 GHz).
I would expect RTEMS/vxWorks to even perform a bit better.
- Till
record (ai, "DZ:TIMESTAMP")
    field (DTYP, "Soft Timestamp")
    field (SCAN, ".0002 second")
    field (PREC, "9")
    field (EGU,  "sec")
    field (FLNK, "DZ:TIMEDIFF")
record (calc, "DZ:TIMEDIFF")
    field (INPA, "DZ:TIMEDIFF.B")
    field (INPB, "DZ:TIMESTAMP")
    field (CALC, "A?B-A:0")
    field (PREC, "9")
    field (EGU,  "sec")
    field (FLNK, "DZ:MAXTIMEDIFF")
record (calc, "DZ:MAXTIMEDIFF")
    field (INPA, "DZ:TIMEDIFF")
    field (INPB, "DZ:MAXTIMEDIFF")
    field (CALC, "A>B?A:B")
    field (PREC, "9")
    field (EGU,  "sec")
Re: Increasing scan rate to 10 kHz Andrew Johnson
Re: Increasing scan rate to 10 kHz Till Straumann
Prev: Re: Agilent 33522A Function / Arbitrary Waveform Generator Michael Johnson
Next: Re: Increasing scan rate to 10 kHz Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Increasing scan rate to 10 kHz Till Straumann
Next: A call to 'assert(capacity != 0)' by thread‏ Emmanuel Mayssat
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
