1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VLANS designing,Geographical vs functional?
To: Zhang Yuliang <[email protected]>
Date: Tue, 7 Jan 2014 22:22:28 -1000 (HST)
By all means functional.
Coming from a site distributed over 3 locations, the most accessible
(office) being 35 miles away form the ones doing the work (telescopes),
you want to have everything you can locate to the (in our case 'office')
local site at the local site (the main server for one of our telescopes
is a virtual machine on a server at the office site).
You may or will need geographical when you access hardware directly
(limitation of line/bus lengths. If you can go over IP this doesn't apply - or may depend on your data rate).
Aloha,
Maren
On Wed, 8 Jan 2014, Zhang Yuliang wrote:
Hello all,
We are designing VLANS for CSNS(China Spallation Neutron Source).  I want to know which method do you choose in your site, geographical or functional?  Any advice? Thanks in advance.
Zhang  Yuliang
VLANS designing,Geographical vs functional? Zhang Yuliang
Prev: VLANS designing,Geographical vs functional? Zhang Yuliang
Next: Agilent 33522A Function / Arbitrary Waveform Generator Michael Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: VLANS designing,Geographical vs functional? Emmanuel Mayssat
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
