Am Donnerstag, 19. Dezember 2013, 12:40:52 schrieb Andrew Johnson:
> On 12/19/2013 11:40 AM, Mark Rivers wrote:
> [...] if
> seq-2.1.15 has added the variable to a header file that declaration must
> be marked with epicsShareExtern which on Windows expands to either
> #define epicsShareExtern __declspec(dllexport) extern
> or
> #define epicsShareExtern __declspec(dllimport) extern
> depending on whether the header is being included by a file that will be
> part of the same DLL as seq_if.c or must be imported from that DLL.
> I guess Ben's issue might be that he has no header file declaring this
> variable, so the compiler never gets told whether it's going to be an
> import or an export. The solution should thus be to add a suitably
> decorated declaration of the variable to an appropriate header file.
Hi Andrew
thanks for your input. I intentionally did not declare the variable in a
header file because it is a crude hack I added for the tests and was never
meant for public consumption.
Peter Heesterman reported that adding epicsShareExtern inside the C file
solves the build problem so that is what I did. The code in 2.1.16 slightly
differs from his proposed fix because gcc gave a warning about initializing a
variable that was declared extern, so the code is now:
epicsShareExtern double seq_sync_timeout;
double seq_sync_timeout = 10.0;
> I suspect that just marking the definition as epicsShareExtern in the
> seq_if.c file may cause problems later.
I hope not ;-) At least, it seems that currently __declspec(dllimport) is not
really needed. If it turns out later that there are cases where it is needed,
I will add the necessary annotation in the code where the variable is used
(inside the tests).
Let me repeat: if you intend your programs to work with future releases of the
sequencer, you should *not* use this variable. I may remove it without further
notice. A proper fix for the issue of configuring the timeout for the SYNC
variants of pvPut and pvGet will appear in version 2.2 of the sequencer.
Cheers
Ben Attachment:
signature.asc
Description: This is a digitally signed message part.
- RE: Build of seq-2.1.15 with VS 2010 fails. Mark Rivers
- Re: Build of seq-2.1.15 with VS 2010 fails. Andrew Johnson
RE: Design strategies for CSS BOY screens tom.cobb
<2013>
notification server Pearson, Matthew R.
<2013>
