On 12/12/2013 11:24 PM, Peter Linardakis wrote:
Where/when should I expect the debug messages from the PM304 driver to appear? I don't seem to see any on top of what we had?
Hello Peter,
After iocInit you should have seen,
"motor_init, return from pasynOctetSyncIO->connect for port %s = %d, pasynUser=%p\n"
if there are no errors up to that point, or,
"motor_init: *PM304 driver disabled*\n");
"PM304Setup() is missing from startup script.\n");
if an error where detected.
When you issued the command "var drvPM304Debug 10" did you get an error
message?
drvPM304Debug -- no such variable.
If so then, you need to edit the
motor/motorApp/MclennanSrc/devMclennanMotor.dbd file
by uncommenting this line,
#variable(drvPM304Debug)
then rebuild that directory and your application. Run it.
Hope this helps,
Ron
- Mclennan PM600 motor controller Peter Linardakis
- RE: Mclennan PM600 motor controller Mark Rivers
- RE: Mclennan PM600 motor controller Peter Linardakis
- RE: Mclennan PM600 motor controller nick.rees
Re: pilatus detecotr modify FileName problem Matt Newville
<2013>
Re: Mclennan PM600 motor controller Torsten Bögershausen
<2013>
