> Your AllInterlocks record has SCAN set to "I/O Intr" so forward-linking > to it with a database link will not cause it to process. If you want it > to process on both I/O Interrupt and from the forward link, you will > have to make the forward-link a CA link, so Mark's suggestion above was > almost right. Try this instead:
In the meantime, I am trying to wrap my head around a I/O Intr record whose processing is also triggered by a FLNK. Although it can be programmed, in practical terms it doesn't make sense to me. -- E
