1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: which time/timestamp format to use for an EPICS facility?
To: "Konrad, Martin" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 9 Dec 2013 16:01:48 +0000
Hello Konrad
For immediate conversion (option 1), the simplest is to get the TAI/UTC offset from the GMC through the PTP hardware (PCI/PXI board or on-board chipset).  We tested that on our NI PXI boards and on on-board Intel chipsets. It works in both cases but we don't use.
For later conversion (option 2), the software needs a copy of the leap second table (with all history). This table can change twice a year but can be cached on the site network. This is the procedure we use.
Franck
-----Original Message-----
Sent: 09 December 2013 16:33
To: EPICS Tech Talk
Cc: Di Maio Franck; Benoit
Subject: Re: which time/timestamp format to use for an EPICS facility?
Hi Franck,
it's good to hear that ITER is prefering TAI over UTC as well :-)
> Actually, we are suppressing POSIX UTC from timing boards' drivers
> only & convert to UTC for applications (inc. EPICS records).
What exactly does converting from TAI to UTC for an EPICS record mean? I see two ways to do that:
1. Convert from TAI to UTC. This requires leap second information on all EPICS IOCs.
2. Just copy the TAI timestamp into an EPICS timestamp and let the clients do the conversion. Since TAI has no leap seconds this should work smoothly. But strictly speaking this is against the definition of EPICS timestamps (which are defined to be in UTC - see epicsTime.h).
If you chose 1.: Do you periodically download the leap second information from a central server into all your IOCs? How do you deal with the fact that EPICS timestamps do not have a representation for leap seconds?
If you chose 2.: How do you make sure all your clients are converting time in the right way (including leap seconds)? Do you have any procedures in place for that?
Thanks a lot,
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
which time/timestamp format to use for an EPICS facility? Konrad, Martin
Re: which time/timestamp format to use for an EPICS facility? Konrad, Martin
RE: which time/timestamp format to use for an EPICS facility? Di Maio Franck
Re: which time/timestamp format to use for an EPICS facility? Benoit
Prev: Re: which time/timestamp format to use for an EPICS facility? Konrad, Martin
Next: CSS Boy - control a button with keyboard shortcut Maurizio Montis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: single script native builds EPICS-­3­-14-­12 on x86_PC and BBB (BeagleBone Black); Ubuntu-­12-­04-­LTS (x86_PC) and Angstrom (BBB) Linux Keith Parker
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
