1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: iocsh and redirection
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 06 Dec 2013 12:24:17 -0500
All,
I was experimenting with redirection in the iocsh and the results were not as I expected.
I have used commands like
dbl>records.txt
in the past and they work fine.
So I created an example IOC (makeBaseApp.pl -t example) and tried:
epics> 1>test.txt
epics> dbl
and got:
Can't open "": No such file or directory.
the file test.txt was created but was empty.
Running the same test on another computer might produce
epics> 1>test.txt
epics> dbl
Can't open "ØîØð8": No such file or directory.
again test.txt is created but empty.
And interestingly on a third computer
epics> 1>test.txt
epics> dbl
will create test.txt but will output a list of records to a file named "èþ8Þ"
BTW, I was playing with this because I wanted to redirect stderr to a file. The App Developer Guide mentions epicsStdioRedirect and I was wondering what it would take to get redirection to work in any specific IOC.
Regards and thanks,
John Dobbins
Cornell University
Re: iocsh and redirection Eric Norum
RE: iocsh and redirection Heesterman, Peter J
Prev: Re: which time/timestamp format to use for an EPICS facility? Konrad, Martin
Next: Re: iocsh and redirection Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Issues Regarding Installing MEDM on Ubuntu 12.04 X86_64 computer Dirk Zimoch
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
