1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EpicsSharp issues
From: "Christopher J. Pendleton" <[email protected]>
To: "'Bertrand Alain Gregor'" <[email protected]>
Cc: [email protected]
Date: Mon, 2 Dec 2013 11:39:58 -0500
Thanks again Alain.
If I want to get PV limits, I see that I can use ExtControl type, but I do not see a timestamp in this type. Is there a single type I can use to access both of these properties, or do I need to use ExtControl and ExtTimeType?
Chris
From: Bertrand Alain Gregor [mailto:[email protected]]
Sent: Monday, December 02, 2013 2:18 AM
To: Christopher J. Pendleton
I was calling the wrong DateTime constructor due to the fact I wasn't passing long values. I tested the time stamp and from what I can see, now it seems to show the same value as the standard epics client. Let me know if it works for you.
Sincerely,
Alain Bertrand
From: Christopher J. Pendleton [mailto:[email protected]]
Sent: Saturday, November 30, 2013 17:32
To: Bertrand Alain Gregor
Thanks again Alain. That works much better. I see the data and I see the timestamp changing.
However, the converted date and time seem wrong. This is the value of ExtTimeType<float[]>.Time (incorrect):
{12/31/1989 6:59:31 PM}
I run a python camonitor on the same PV and I see this (correct):
testi3200_in_current 2013-11-30 11:28:26.85700 <array size=32, type=float>
-Chris
Sent: Wednesday, November 27, 2013 5:06 AM
Hi Chris,
I must admit I never worked with floats and the C# lib so far, nor I used much the arrays. Anyhow I found quite a few issues in my code and hope to have fixed them. There is a few things I'm not 100% sure however it seems to work now. So please try to grab the latest version and see if it works for you.
Sincerely,
Alain
Sent: Tuesday, November 26, 2013 16:09
Would you expect this code to work?
    static class Program
        [STAThread]
        static void Main()
            EpicsClient client = new EpicsClient();
            EpicsChannel<ExtTimeType<float[]>> record =
                client.CreateChannel<ExtTimeType<float[]>>("r_I128_channels_test");
            record.MonitorChanged += new EpicsDelegate<ExtTimeType<float[]>>(record_MonitorChanged);
            Console.ReadKey();
        static void record_MonitorChanged(EpicsChannel<ExtTimeType<float[]>> sender, ExtTimeType<float[]> newValue)
            Console.WriteLine("Help!");
I see a similar exception as before in the console window:
System.Collections.Generic.KeyNotFoundException: The given key was not present i
n the dictionary.
   at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
   at PSI.EpicsClient2.EpicsChannel`1.<Disconnect>b__3(EpicsChannel action) in D
:\Projects\epicssharp\client\EpicsGenericChannel.cs:line 105
Chris
Sent: Tuesday, November 26, 2013 8:04 AM
Ask for an  ExtTimeType<TType> where TType is the type you want for the data (string, float or whatever)
And you should receive the timestamp as Time property of it.
Cheers,
Alain Bertrand
Sent: Tuesday, November 26, 2013 14:00
I am actually talking about the client. Can you point me to some documentation/example code that accesses timestamps?
Chris
Sent: ‎11/‎25/‎2013 11:31 PM
Subject: Re: EpicsSharp issues
The client should be able to reach any PV information, so I guess you are talking about the server side implementation. Right? The server is designed in such a way that you can define your own types and have any properties you want visible through Epics. So units, limits or whatever else you want have should be doable already.
Cheers,
Alain
On 11/25/2013 9:48 PM, Christopher J. Pendleton wrote:
Hi Alain.
The new code works. I appreciate your efforts and quick response. I was wondering if there were any plans to expose some other PV information such as timestamp, units, limits, etc. in a future version of EpicsSharp?
Chris
Re: EpicsSharp issues Alain Bertrand
RE: EpicsSharp issues Christopher J. Pendleton
RE: EpicsSharp issues Bertrand Alain Gregor
Prev: New areaDetector plugin: adPython tom.cobb
Next: Re: Fw: Alarm Handler Robert Soliday
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EpicsSharp issues Bertrand Alain Gregor
Next: Re: EpicsSharp issues Alain Bertrand
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
