1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: All Pvs disconnected
To: Julio Calvo <[email protected]>, techtalkForo <[email protected]>
Date: Thu, 28 Nov 2013 16:42:03 +0000
On the machine that is working type:
printenv | grep EPICS
at the shell and
epicsPrtEnvParams
at the IOC prompt.
On the machine that is not working do the same thing.
And on the machine that is not working at the shell do
caget SOME_PV_NAME
cainfo SOME_PV_NAME
It could be you will be able to access the PVs using the caget and cainfo commands, which use the C CA library, but not from CSS which uses the Java CA library.  I think CSS uses a different mechanism to set EPICS_CA_ADDR_LIST, etc.
Sent: Thursday, November 28, 2013 10:31 AM
To: Mark Rivers; techtalkForo
Subject: Re: All Pvs disconnected
I have changed that variables but still not working.
I have the same configuration of that machine, here, and it works, without internet. And it is not connected, no cable.
Thanks.
Julio.
El Jueves 28 de noviembre de 2013 17:01, Mark Rivers <[email protected]> escribió:
If the Ethernet port is disconnected then CA does not work.  I think if you set EPICS_CA_AUTO_ADDR_LIST=NO and EPICS_CA_ADDR_LIST=localhost it will work, but I am not certain.
You could also just plug the Ethernet cable into a cheap switch with nothing else connected to it :-)
From: [email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>] on behalf of Julio Calvo [[email protected]<mailto:[email protected]>]
Sent: Thursday, November 28, 2013 9:53 AM
To: techtalkForo
Subject: All Pvs disconnected
Hello,
I have move a computer from my lab, it was working perfectly, it was connected to internet, now, this computer is in other place without internet connection for security reasons. I have open the IOC, pvs are ok after dbl. But CSS GUI appears as disconnected, any idea?. I have done this several times and I never found this problem. Do I have to configure something?.
Thanks.
Julio.
All Pvs disconnected Julio Calvo
RE: All Pvs disconnected Mark Rivers
Re: All Pvs disconnected Julio Calvo
Prev: Re: All Pvs disconnected Julio Calvo
Next: Re: Increasing scan rate to 10 kHz Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: FW: All Pvs disconnected Mark Rivers
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
