1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Alarm Handler
To: "Anderson, Janet B." <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 27 Nov 2013 16:20:29 +0530
Thanks Janet..
But I was using alh_1_24 for Alarm handler for base 3.14.12.3.
 I had created extension directory into which I copied the content of alh_1_24 and renamed it as src as described in http://www.aps.anl.gov/epics/extensions/config/index.php
When I compiled it (by make on src), it got terminated ...fatal error: Xm/Xm.h :No such File or directory
Thanks & Regards
Swati Soni
To: Swati Soni2 <[email protected]>, "[email protected]" <[email protected]>
Date: 11/26/2013 08:57 PM
The optional ALARMHANDLER environment variable should specify the directory where your Alarm Handler input configuration files reside and where the Alarm Handler output log files should be written.  The PATH  environment variable should include the directory of the alarm handler executable.
Janet
From: [email protected] [[email protected]] on behalf of Swati Soni2 [[email protected]]
Sent:
Tuesday, November 26, 2013 6:04 AM
To:
[email protected]
Subject:
Fw: Alarm Handler
Hi
I am using EPICS 3.14.12.3 on fedora..I want to install Alarm handler extension.
Can anyone tell me how to set environment ?
I had used
              setenv ALARMHANDLER /<path name of alh1_3_31>
Bt it throws error commnad not found....Is there any other command to get it installed??
I am following
http://www.aps.anl.gov/epics/EpicsDocumentation/ExtensionsManuals/AlarmHandler/alhUserGuide-1.2.33/ALHUserGuide.html
Thanks & Regards
Swati Soni
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
Re: Alarm Handler Pierrick Hanlet
Fw: Alarm Handler Swati Soni2
RE: Alarm Handler Anderson, Janet B.
Prev: RE: EpicsSharp issues Bertrand Alain Gregor
Next: Re: Alarm Handler Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Alarm Handler Anderson, Janet B.
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
