> From:
[email protected]> To:
[email protected];
[email protected]> Date: Fri, 22 Nov 2013 17:08:02 -0800
> Subject: RE: Breakpoint tables: Raw value must be integer?!?
> * Inputs:
> * A = Gap (mm)
> * D = Breakpoint Table Index (index in menuConvert.dbd)
> * Outputs:
> * H = Value from the Breakpoint Table
> * J = Previous Breakpoint Table Index
> * DPVT = Pointer to Breakpoint Table
> * L = Last Breakpoint
> * VAL = Magnetic Field (T)
I wouldn't mind looking at the sample db file that goes with your code.
Is there a way to convert the STRING in the menu convert to its integer?
Hopefully yes.
I would much prefer to be able to link the asub record entry to the name of the table.
Then the debugging of an IOC is trivial.
The issue with the CALC solution is that the work around requires to modify the table itself
(i.e multiply by 1000 the raw values). You cannot use this method if the data is auto-generated from real samples.
(i.e. calibration table)
Obviously if I am nit picking is because I am talking about a large scale deployment of breakpoint tables in my IOCs, not just for one record.
Again, is there a way to convert a STRING in a asub parameter to its corresponding menuConvert integer?
E
