Hi Carsten,
Now I understand the system and it is working thanks to your help.
Thank you so very much!
Antonio Borondo
-----Mensaje original-----
De: Carsten Winkler [mailto:[email protected]]
Enviado el: lunes, 25 de noviembre de 2013 13:23
Para: [email protected]; [email protected]
CC: [email protected]
Asunto: Re: Error database DTYP
Hi Antonio,
EPICS_CA_AUTO_ADDR_LIST and EPICS_CA_ADDR_LIST are environment variables and will be used by every channel access component at same computer. In your case, you need it for your Linux clients only. A good documentation you can find here: http://www.aps.anl.gov/epics/docs/AES2011/05-Protocol.pdf
BTW did you notice your typo in EPICS_CA_ADDR_LIST?
Regards
Carsten
Am 25.11.2013 13:08, schrieb Antonio Borondo:
> Hi Carsten,
> Great to know that! Now I have a clearly idea of how I have to deploy the network.
> But my problems has not finished yet: I get the next error message when I am executing camonitor within the MicroBox:
> SAI:STATUS *** Not connected (PV not found)
> CA.Client.Exception...............................................
> Warning: "Identical process variable names on multiple servers"
> Context: "Channel: "SAI:STATUS", Connecting to: 192.168.20.2:5064, Ignored:
> IFMIFMICROBOX:5064"
> Source File: ..\cac.cpp line 1297
> Current Time: Mon Nov 25 2013 13:50:02.666748232
> SAI:STATUS 2013-11-25 13:50:02.378366
> My MicroBox has two network interfaces: the first one connected to the PLC (192.168.29.2) and the second one connected to the linux PC (172.31.110.199).
> I have read the same problem by the Internet and people suggest setting the variables EPICS_CA_AUTO_ADDR_LIST=NO and ECPIS_CA_ADDR_LIST=<Broadcast address> but I do not know if it is possible in OpcIocShell.
> Could you help me with that?
> Thank you very much,
> Antonio Borondo
> Enviado el: lunes, 25 de noviembre de 2013 12:52
> Hi Antonio,
> you need only one soft IOC (the one at the MicroBox). In your case you have to run the OpcIocShell to have an interface between OPC and EPICS.
> At Linux you only need channel access clients as caget, camonitor or higher level clients. A standard soft IOC doesn't support the DTYP "OPC". This is a special feature of the OpcIocShell.
> Hope this resolves your problem
> Carsten Winkler
> Am 25.11.2013 11:46, schrieb Antonio Borondo:
>> Hi all,
>> I am trying to deploy an EPICS network between a linux PC, a MicroBox
>> with OPC Server and a Siemens PLC.
>> The MicroBox basically gets the registers from the PLC, stores them
>> into OPC Server database and after puts them into EPICS database using OpcIocShell.
>> On the linux PC side I have developed the EPICS IOC which loads the
>> same data base.
>> My problem comes when I start my IOC and I get the next error message
>> for each PV of the data base:
>> Can't set "<PV NAME>.DTYP" to "opc"
>> Error at or before ")" in path "." file "opc.db" line x"
>> Any ideas about how to resolve it?
>> Antonio Borondo
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch,
> stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas
> Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
D-14109 Berlin
- Error database DTYP Antonio Borondo
- Re: Error database DTYP Carsten Winkler
- RE: Error database DTYP Antonio Borondo
RE: Breakpoint tables: Raw value must be integer?!? Steiner, Mathias
<2013>
EPICS on RTEMS 4.11 Nadia Gruman
<2013>
