1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Convertion for asynFloat64
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Mon, 25 Nov 2013 11:30:38 +0100
Thanks for the intersting suggestion... I did try both (writing in OCAL and in A) and it is working!
But I think this is too much "hacking" and I am wondering of the bad consequence of this action in the future...
I have decided to finally keep with a temporary record which is more "standard" use.
Cheers,
Benoit
Benoit RAT
www.neub.co.nr
On Fri, Nov 22, 2013 at 6:39 PM, J. Lewis Muir <[email protected]> wrote:
On 11/22/13 11:16 AM, Andrew Johnson wrote:
> Hi Lewis,
> On 11/22/2013 10:53 AM, J. Lewis Muir wrote:
>> EPICS Base developers, it would be great if a write to the calcout
>> VAL field did trigger record processing.  But maybe there's a reason
>> why it doesn't?
> I didn't design that record type, but why would you want to be able
> to write a value to a field when that value is normally going to be
> immediately overwritten when the record processes?
Hi, Andrew.
My only reason is just from a PV "API" standpoint.  Lots of people leave
off the ".VAL" suffix from the PV name, so in this case, they wouldn't
be able to do that unless the VAL field was pp(TRUE).
> Note that the pp(TRUE) setting only applies when doing a put through
> CA, a database link can directly control whether processing happens or
> not.
Interesting.  Thanks for pointing that out; I didn't know that.
> In this particular case you're getting clever with the record so I do
> understand the request, but the ability to access the VAL field from a
> Calc _expression_ is a lot newer than the calcout record. Note also that
> in an OCAL _expression_, VAL actually returns the last value from the
> OVAL field, not the VAL field, so setting OCAL to "1000 * VAL" would
> not do the scaling of the VAL field that Benoit wants it to do.
Right, that's what I said when I wrote, "So maybe you could write to
that [the OVAL field], and use the OCAL _expression_ and set DOPT to 'Use
OCAL' and get the behavior you want by writing to OVAL instead of VAL
(albeit confusing)?"
Lewis
Convertion for asynFloat64 Benoit
Re: Convertion for asynFloat64 J. Lewis Muir
Re: Convertion for asynFloat64 Benoit
Re: Convertion for asynFloat64 Andrew Johnson
Prev: RE: Rejected email Bertrand Alain Gregor
Next: Error database DTYP Antonio Borondo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Convertion for asynFloat64 J. Lewis Muir
Next: StreamDevice Checksum Pseudo-Converter Florian Feldbauer
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
