1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Why should I care about breakpoint table monotonicity?
To: Emmanuel Mayssat <[email protected]>
Date: Fri, 22 Nov 2013 13:13:16 -0600
Hi Emmanuel,
On 11/22/2013 12:56 PM, Emmanuel Mayssat wrote:
 > In 3.14.x the same code that loads DBD files into the IOC is used in the
 > dbExpand program, so it does the same checking. You can give dbExpand a
 > -b flag to disable the monotonicity check though. Put
 > DBEXPAND += -b
 > into your Makefile to add that flag to all calls to dbExpand (there is a
Not in 3.14.11...
No, it was added in 3.14.12.2, almost 2 years ago:
revno: 12295
author: [email protected]
committer: Andrew Johnson <[email protected]>
branch nick: 3.14
timestamp: Mon 2011-11-21 11:33:26 -0600
message:
  dbStatic: Added -b option to dbExpand
  -b turns off monotonic checking of breakpoint tables.
You may be able to apply the changes to your copy though, see
http://bazaar.launchpad.net/~epics-core/epics-base/3.14/revision/12295
Am I missing something?
3.14.11 is over 4 years old now, maybe consider upgrading? 3.14.12.4 will be out soon.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
RE: Why should I care about breakpoint table monotonicity? Hartman, Steven M.
RE: Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
Re: Why should I care about breakpoint table monotonicity? Andrew Johnson
Prev: RE: Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
Next: Breakpoint tables: Raw value must be integer?!? Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Job openings at PSI Dirk Zimoch
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
