On 11/22/13 11:16 AM, Andrew Johnson wrote:
> Hi Lewis,
> On 11/22/2013 10:53 AM, J. Lewis Muir wrote:
>> EPICS Base developers, it would be great if a write to the calcout
>> VAL field did trigger record processing. But maybe there's a reason
>> why it doesn't?
> I didn't design that record type, but why would you want to be able
> to write a value to a field when that value is normally going to be
> immediately overwritten when the record processes?
Hi, Andrew.
My only reason is just from a PV "API" standpoint. Lots of people leave
off the ".VAL" suffix from the PV name, so in this case, they wouldn't
be able to do that unless the VAL field was pp(TRUE).
> Note that the pp(TRUE) setting only applies when doing a put through
> CA, a database link can directly control whether processing happens or
> not.
Interesting. Thanks for pointing that out; I didn't know that.
> In this particular case you're getting clever with the record so I do
> understand the request, but the ability to access the VAL field from a
> Calc expression is a lot newer than the calcout record. Note also that
> in an OCAL expression, VAL actually returns the last value from the
> OVAL field, not the VAL field, so setting OCAL to "1000 * VAL" would
> not do the scaling of the VAL field that Benoit wants it to do.
Right, that's what I said when I wrote, "So maybe you could write to
that [the OVAL field], and use the OCAL expression and set DOPT to 'Use
OCAL' and get the behavior you want by writing to OVAL instead of VAL
(albeit confusing)?"
Lewis
- Re: Convertion for asynFloat64 Benoit
- Convertion for asynFloat64 Benoit
- Re: Convertion for asynFloat64 J. Lewis Muir
- Re: Convertion for asynFloat64 Andrew Johnson
RE: Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
<2013>
<2013>
