Hi Lewis,
On 11/22/2013 10:53 AM, J. Lewis Muir wrote:
EPICS Base developers, it would be great if a write to the calcout VAL
field did trigger record processing. But maybe there's a reason why it
doesn't?
I didn't design that record type, but why would you want to be able to
write a value to a field when that value is normally going to be
immediately overwritten when the record processes? Note that the
pp(TRUE) setting only applies when doing a put through CA, a database
link can directly control whether processing happens or not.
In this particular case you're getting clever with the record so I do
understand the request, but the ability to access the VAL field from a
Calc expression is a lot newer than the calcout record. Note also that
in an OCAL expression, VAL actually returns the last value from the OVAL
field, not the VAL field, so setting OCAL to "1000 * VAL" would not do
the scaling of the VAL field that Benoit wants it to do.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: Convertion for asynFloat64 J. Lewis Muir
- Convertion for asynFloat64 Benoit
- Re: Convertion for asynFloat64 Benoit
<2013>
<2013>
