1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS EPICS PV connectivity issue
To: Ralph Lange <[email protected]>, Andrew Johnson <[email protected]>, Kasemir Kai <[email protected]>
Cc: [email protected]
Date: Fri, 22 Nov 2013 09:58:35 +0100
Hello.
Thank you Ralph, Andrew and Kasemir for your replies. All was my fault because and a beginner... 192.168.1.255 and auto_addr_list turned on is working perfectly!
Thank you so much again
El 21/11/2013 20:03, Ralph Lange escribió:
On Thu Nov 21 2013 19:24:30 GMT+0100 (CET), Juan Manuel Lozano <[email protected]> wrote:
Hi.
P.D: I'm not a subscriber but this e-mail is a reply to this tech-talk http://www.aps.anl.gov/epics/tech-talk/2011/msg01405.php If you can publish it anyway I'll be very grateful
I have the same problem. I'll describe my system:
  • IOC is in a virtual machine running Linux (192.168.1.45)
  • CSS is in the host machine, running Windows 7 (192.168.1.33)
  • Both systems, as you can see, share the same subnet, which is 192.168.1.0/24
If I configure CSS with addr_list to 192.168.1.45 all works perfectly, but IOC's IP is dynamic so I want to force CSS to discover PVs. When I turn on auto_addr_list in CSS and leave addr_list empty, it doesn't connect. If I put 192.168.1.0 in addr_list field doesn't connect neither.
Have you tried setting the addr_list field to the broadcast address of your network, i.e. 192.168.1.255?
~Ralph
Juan Manuel Lozano Contreras
Tlf: (+34) 650 24 66 10
E-mail: [email protected]
Parque Empresarial La Raya - PCTH - Despacho 3
Calle Industria 59, 21110
Aljaraque, Huelva, España
CSS EPICS PV connectivity issue Juan Manuel Lozano
Re: CSS EPICS PV connectivity issue Ralph Lange
Prev: RE: Why should I care about breakpoint table monotonicity? Hartman, Steven M.
Next: RE: areaDetector for PGR Flea3 GigE camera tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CSS EPICS PV connectivity issue Ralph Lange
Next: Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
