1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: areaDetector for PGR Flea3 GigE camera
To: <[email protected]>
Cc: [email protected]
Date: Fri, 22 Nov 2013 09:39:16 +0000
We've done some tests and it seems that the point grey cameras don't like having their feature values read out while they are requiring. If you set
the GETFEATURES pv to No, then you should be able to set pgrPixelBigEndia to Yes (which is needed for Mono16 mode).
Tom Cobb
> -----Original Message-----
> From: Yingbing Yan [mailto:[email protected]]
> Sent: 21 November 2013 14:16
> To: Cobb, Tom (DLSLtd,RAL,TEC)
> Dear Tom,
> I can got the out from the camera. There is no error messages. Please
> see the file attached tiff and hdf5 file.
> Best regards,
> Yingbing Yan
> From: [email protected]
> To: [email protected], [email protected]
> Date: Thu, 21 Nov 2013 13:25:08 +0000
> Hi,
> I have not tried the 16-bit mode of point grey cameras, but I have one
> for testing so I will be trying it out over the next few days. When you
> set it to Mono16 mode, do you get any image at all out of the camera?
> What does the image look like? Are there any error messages?
> Thanks,
> Tom Cobb
> > From: [email protected] [mailto:tech-talk-
> > [email protected]] On Behalf Of Yingbing Yan
> > Sent: 21 November 2013 11:43
> > Subject: areaDetector for PGR Flea3 GigE camera
> > Hi,
> > I am using areaDetector 1-9 and aravisGigE-0-1-15dls6 for Point Grey
> > Research Flea3 and Basler GigE camera. For Mono8 mode they work fine.
> > For Mono16 mode, the Basler camera works fine
> > ($(P)$(R)GevDeviceModeIsB_RBV is Yes), but Point Grey Research Flea3
> > can
> > not work ($(P)$(R)pgrPixelBigEndia_RBV and
> > is No).
> > If the parameters of pgrPixelBigEndia and GevDeviceModeIsBigEndian
> were
> > modified, they will be reset to No, while I can see the correct image
> > at
> > that moment. How could I fixed the pgrPixelBigEndia?
> > Best regards,
> > Yingbing Yan
> > Dept. of Beam Instrumentation & Control
> > Shanghai Synchrotron Radiation Facility (SSRF)
areaDetector for PGR Flea3 GigE camera Yingbing Yan
RE: areaDetector for PGR Flea3 GigE camera tom.cobb
Prev: Re: CSS EPICS PV connectivity issue Juan Manuel Lozano
Next: RE: areaDetector for a Basler GigE camera tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: areaDetector for PGR Flea3 GigE camera tom.cobb
Next: Alarm Handler Swati Soni2
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
