Hi Garth,
There have been some significant modifications made to the version of
msi which is found in Base 3.15. I'm not sure if they will completely
solve your problem, but you might want to check the documentation at
http://www.aps.anl.gov/epics/base/R3-15/0-docs/msi.html which shows the
new global syntax in the substitutions file. There are more docs
including an EBNF grammar in the Application Developers Guide at
http://www.aps.anl.gov/epics/base/R3-15/0-docs/AppDevGuide/node7.html#SECTION007220000000000000000
-- the same syntax works in both msi and dbLoadTemplate(). If you want
to try out the new msi it should be possible to extract just the
src/ioc/dbtemplate/msi.c file and build it against a 3.14.12 version of
Base.
You can also of course use any templating language you like to write
substitutions. We provide msi which shares the dbLoadTemplate syntax,
but other sites have written their own tools when they had specific
needs which msi can't meet. You could modify msi as well, but I would
suggest starting from the 3.15 version if you think you might want to
offer your changes back to us.
HTH,
- Andrew
On 11/15/2013 06:15 PM, Brown, Garth wrote:
I'll add a few tangentially related thoughts on how msi/macLib might
be modified. It would be nice if there was a way to keep a macro with
a default value in a template unexpanded. That is, if sample.template
contains the line
field(X, "$(MYX=3)" )
then sample.substitutions could have a way to indicate that MYX
shouldn't be expanded and should retain the default value part, so
that sample.db still had exactly that line. As it is, you can leave
MYX undefined, which expands to
field(X, "3" )
Or you can have in the substitutions { MYX='$(MYX)' }, which expands
to
field(X, "$(MYX)" ) # default value is lost
The macro with default can't survive msi unchanged.
If there were a way to leave the macro undefined with the default
value intact, I could solve my problem with two levels of
substitutions files: a general substitutions file that contained
macros with defaults for everywhere, and environment specific
substitutions files that used the output of the general one as a
template.
Getting more technical about how that might work, you could interpret
{ MYX=$(MYX) } recursive definition as not wanting the macro
substituted, rather than as an error condition. Right now, macLib
will turn this into $(MYX, recursive), indicating an error and losing
the default value.
I had a look in macCore.c where this case is handled, and didn't
immediately see how to implement that. The recursive definition is
detected one call stack level below where the default value is
specified.
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: Substitutions defaults and tricks Bruce Hill
- Re: Substitutions defaults and tricks Michael Davidsaver
- Substitutions defaults and tricks Brown, Garth
- Re: Substitutions defaults and tricks Pietryla, Anthony F.
- RE: Substitutions defaults and tricks Brown, Garth
<2013>
<2013>
