For building an IOC that uses asyn, autosave, streamDevice, and std I would recommend just downloading the synApps module:
http://www.aps.anl.gov/bcda/synApps/
If you do that then everything is all set up for you, with dependencies between modules, and a top-level Makefile. I also has instructions on how to install
and build it:
http://www.aps.anl.gov/bcda/synApps/synApps_5_7.html
For extensions you only need to the Top file, not the Configure file. You install that, and then install the individual extensions under extensions/src. You
edit extensions/configure/RELEASE to set the path to EPICS base and some other things. Then you run make at the top level of extensions.
Hello,
Presently i am working on system already installed EPICS. I started and learning with developing computer serial port driver.
Now i want to establish another system. I tried to install epics extension and modules. But can't understand how to install extension and modules.
I downloaded
extensionsTop_20120904.tar.gz, and
extensionsConfigure_20070703.tar.gz but don't know what to do with this.
I also downloaded
asyn4-21.tar.gz, autosave_R5-1.tar.gz , camonitor_cvs.tar.gz , StreamDevice-2-6.tgz , std_R3-2.tar.gz etc but don't know how to install it ...
Is it enough to just untar all these modules?
Thank you
