1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: areaDetector for a Basler GigE camera
To: "Sorgenfrei, Florian" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 13 Nov 2013 22:59:20 +0000
Hi Florian,
Andrew Johnson just pointed out that the Debian distribution of areaDetector has some of the directories missing.  I was not aware of this.  Presumably it is because of copyright issues on software like netCDF, perhaps because I neglected to include a netCDF copyright file in my distribution.  I will work with Michael Davidsaver to try to fix that.
Meanwhile you can just get the areaDetector distribution from here:
http://cars9.uchicago.edu/software/epics/areaDetector.html
That will have the required netCDF files.
Sent: Wednesday, November 13, 2013 3:45 PM
To: Sorgenfrei, Florian; [email protected]
Hi Florian,
libnetCDF.a is built as part of areaDetector from ADApp/netCDFSrc.
Do you see this file:
$(AREA_DETECTOR)/lib/linux-x86_64/libnetCDF.a
I am assuming your ARCH is linux-x86_64.  Is that true?
Can you send the output of "make" when it fails?
From: [email protected] [[email protected]] on behalf of Sorgenfrei, Florian [[email protected]]
Sent: Wednesday, November 13, 2013 2:56 PM
To: [email protected]
Subject: areaDetector for a Basler GigE camera
Hi guys,
I recently started trying to read out some Basler GigE cameras with the areadetector module. What I want to do is mainly having a camera image and extracting the widths and position of (laser) beams impinging on these cameras.
We are using Debian wheezy and I have installed the latest epics package (including epics-areadetector, epics-areadetector-dev) using the NSLS repository. After searching how to get the Basler camera working with the areadetector I stumbled over the files from the Diamond Light Source. It looked to me that they have a step-by-step guide and I thought this might help. I downloaded the files from the DLS and was kind of quick in installing the aravis driver. I had a few issues with glib but after reading and tweaking the config files I managed that part.  Having arv-tool-0.2 displaying the Basler cameras (along with Fake_1) was already a good sign but here the issues started. I somehow cannot compile the exampleApp since I'm missing libnetCDF.a. I read that for the areadetector module this file is needed but I do not have it and there seems to be no source file for it.
Now I'm wondering if I'm doing something completely wrong and should start from scratch again. I also feel somehow lost in the (typically) not so well documented world of epics. I really tried to gather some hints from all the sites using epics but that didn't work too well.
Any help considering this issue is highly appreciated.
Cheers,
Flo
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: areaDetector for a Basler GigE camera Florian Sorgenfrei
areaDetector for a Basler GigE camera Sorgenfrei, Florian
RE: areaDetector for a Basler GigE camera Mark Rivers
Prev: RE: areaDetector for a Basler GigE camera Mark Rivers
Next: LIB_INSTALLS, static builds and .so files. Shankar, Murali
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: areaDetector for a Basler GigE camera Florian Sorgenfrei
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
