1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: C863 can't answer the PI GCS commands
To: Mi Qingru <[email protected]>
Date: Wed, 13 Nov 2013 14:52:14 +0000
Hi Qingru,
I would say yes, the DLL would be required if your C863’s firmware does not support PIGCS2.  If that’s the case, you should be able to work with PI to update your firmware.  Then the PIGCS2 support in motorR6-8 should work.
Kurt
From: [email protected] [mailto:[email protected]] On Behalf Of Mi Qingru
Sent: Wednesday, November 13, 2013 12:50 AM
To: tech-talk epics
Subject: C863 can't answer the PI GCS commands
    I applied the PIGCS2Src in motorR6-8 to the C863 motor controller.
    There was an error as starting up:
        drvAsynIPPortConfigure(“C863”, "192.168.127.1:4001",0,0,0)
        PI_GCS2_CreateController(“PI”,"C863","1”,"","","100”,"1000”)
        PIGCSController: sendAndReceive error calling writeRead, output=*IDN? error=192.168.127.12:4001 timeout:Resource temporarily.
        read from C863:
        PIasynController: unknown controller type C863:
    I have tested C863 with old PI module . It worked well.
    It seemed that  C863 hadn’t answer the command.
    PI GCS manual has an introduce  “With current Mercury™ firmware, GCS command support is implemented by a Windows DLL which translates the GCS commands to the native commands the current firmware understands”.
    Does that mean: sending GCS command to C863 must use PI_Mercury_GCS_DLL.lib instead asynOctetSyncIO->write?
Qingru Mi
SSRF
C863 can't answer the PI GCS commands Mi Qingru
Prev: C863 can't answer the PI GCS commands Mi Qingru
Next: areaDetector for a Basler GigE camera Sorgenfrei, Florian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
