On Nov 11, 2013, at 1:08 AM, Swati Soni2 <[email protected]<mailto:[email protected]>> wrote:
I am beginner of EPICS...I had created one OPI file but on opening it is showing the error : Premature end of file
Can anyone tell me how to resolve this issue???
This may be a result of how you create the *.opi file.
If you run CS-Studio, then use File/New, and select "OPI File" from the "BOY" category, this will create a very basic *.opi XML file and open it in the BOY editor.
If you opened that same file in a text editor, you would see that it follows the format
<display typeId="org.csstudio.opibuilder.Display" version="1.0.0">
</display>
On the other hand, if you use other means to create a file that's simply named *.opi, for example via File/New, the use "File" from the "General" category, and name it "test.opi", you will get that error "Failed to open opi file, premature end of file".
That's because this second file is totally empty, it doesn't have any of the expected *.opi file content.
-Kay
- Error while opening OPI Swati Soni2
Re: Subscription updates halting? Dirk Zimoch
RE: autosave failure S_rpcLib_RPC_CANTSEND Mark Rivers
<2013>
PV access over the Network. Ganesh Jangir
<2013>
