Hello Carsten,
Thank you for your reply. Could you please confirm for me that this is done by adding the environment variable to windows via the Windows Advance System Properties > Environment Variables, or is there another configuration file located somewhere that the CALab
vi's refer to?
I have also got the extra problem that there are PV's on different IOC's which I want to access but they have all been setup to different ports. Can you list multiple ports, or do you have to manipulate the variable dynamically in code to change the port number
for each IOC?
Kind Regards,
David
Sent: Wednesday, 6 November 2013 7:05 PM
To: BUTTON, David; [email protected]
Subject: Re: LabVIEW EPICS Communication on ports other than 5064? [SEC=UNCLASSIFIED:For-Official-Use-Only]
Hello Dave,
please set the environment variable EPICS_CA_SERVER_PORT for all systems with running CA Lab clients and they will connect.
You're right, CA Lab runs only on Windows and Linux PCs but not on real-time controllers.
God luck with the EPICS IO Server.
Carsten
Am 06.11.2013 08:26, schrieb BUTTON, David:
Hello,
Locally our EPICS control system has been modified so that the several IOC servers which are running of the computer we call control have had their EPICS_CA_SERVER_PORT
variable set to values other than 5064, ie 49200 and 49212... Needles to say that both the EPICS IO Server native to LabVIEW is now unable to access the PV's, and likewise the CALab vi's can no longer access them either. I am unable to discover if there
is a way to change the "port number" so that I can get either the NI or CALabs vi's working again. The native I/O server is important as it runs on the real-time controllers where I believe the CA Lab vi’s can only run on a windows application. I am only
recently started down this path of LabVIEW EPICS communications, and would greatly appreciate input.
Thanks in advance,
Dave
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Re: LabVIEW EPICS Communication on ports other than 5064? [SEC=UNOFFICIAL] Martin L. Smith
Re: LabVIEW EPICS Communication on ports other than 5064? [SEC=UNCLASSIFIED:For-Official-Use-Only] Carsten Winkler
<2013>
Re: LabVIEW EPICS Communication on ports other than 5064? [SEC=UNCLASSIFIED:For-Official-Use-Only] Andrew Johnson
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
