1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Newport XPS-Q8 and Motor Record - RV120HAHL stage
Date: Fri, 1 Nov 2013 15:13:18 -0600
Good Afternoon,
I am using EPICS R3.14.12, MOTOR 6-5 and ASYN 4-13 with a Newport XPS-Q8 controller with an XPS-DRV03 card to try and move a RV120HAHL stage.  Because the RV120HAHL stage is not supported by the Newport Controller I have configured the RV120CCHL and adjusted the following parameters and then auto tuned the configuration for the stage.
EncoderResolution = 0.0001 ;--- units
MaximumVelocity = 8 ;--- units / s
MaximumAcceleration = 32 ;--- units / s²
HomeSearchMaximumVelocity = 4 ;--- units / s
HomeSearchMaximumAcceleration = 16 ;--- units / s²
MinimumTargetPosition=1;--- units
MaximumTargetPosition=59;--- units
HomePreset=6;--- units
Here is the information from the .ini file for the stage I have configured.
;RV@RV160CCHL@XPS-DRV03
;--- Unit = deg
;--- Configuration_Comment =
;--- Smart stage name
SmartStageName=
;--- Motor driver model parameters
DriverName=XPS-DRV03
DriverMaximumRMSCurrent=1.98;--- A
DriverRMSIntegrationTime=3;--- s
;--- Driver command interface parameters
MotorDriverInterface=AnalogVoltage
ScalingCurrent=5;--- A
CurrentLimit=3.96;--- A
ScalingVoltage=48;--- V
VoltageLimit=45.56;--- V
;--- Position encoder interface parameters
EncoderType=AquadB
EncoderResolution=0.0001;--- units
LinearEncoderCorrection=0;--- ppm
Backlash=0;--- units
CurrentVelocityCutOffFrequency=100;--- Hz
CurrentAccelerationCutOffFrequency=100;--- Hz
PositionerMappingFileName=
PositionerMappingLineNumber=
PositionerMappingMaxPositionError=;--- units
EncoderIndexOffset=0;--- units
;--- Limit sensor input plug parameters
ServitudesType=StandardEORDriverPlug
MaximumVelocity=8;--- units / s
MaximumAcceleration=32;--- units / s2
EmergencyDecelerationMultiplier=4
MinimumJerkTime=0.005;--- s
MaximumJerkTime=0.05;--- s
TrackingCutOffFrequency=25;--- Hz
;--- Home search process parameters
HomeSearchSequenceType=MechanicalZeroAndIndexHomeSearch
HomeSearchMaximumVelocity=4;--- units / s
HomeSearchMaximumAcceleration=16;--- units / s2
HomeSearchTimeOut=86;--- s
HomingSensorOffset=0;--- units
;--- Position servo loop type parameters
CorrectorType=PIDDualFFVoltage
ClosedLoopStatus=Closed
FatalFollowingError=1;--- units
KP=36
KI=650
KD=0.279
KS=0.8
GKP=0
GKD=0
GKI=0
KForm=0;--- units
IntegrationTime=1E+99;--- s
DerivativeFilterCutOffFrequency=4000;--- Hz
DeadBandThreshold=0;--- units
KFeedForwardVelocity=1.815
KFeedForwardAcceleration=0.0010378
KFeedForwardVelocityOpenLoop=1.815
Friction=0;--- V
NotchFrequency1=0;--- Hz
NotchBandwidth1=0;--- Hz
NotchGain1=0
NotchFrequency2=0;--- Hz
NotchBandwidth2=0;--- Hz
NotchGain2=0
;--- Motion done condition mode parameters
MotionDoneMode=Theoretical
After rebooting the controller I am able to successfully use the Newport web interface to initialize, home and move the stage.  However when I try and move the stage with the Motor record I am seeing strange behaviour.
Here is my st.cmd file.
#!./bin/linux-armv5teb/ideasMonoMtr
## You may have to change ideasMonoMtr to something else
## everywhere it appears in this file
#< envPaths
dbLoadDatabase("./dbd/ideasMonoMtr.dbd",0,0)
ideasMonoMtr_registerRecordDeviceDriver(pdbbase)
## Load record instances
dbLoadRecords("./db/IDEAS_MonoMtr.db")
dbLoadRecords("./db/IDEAS_MonoPseudoMtr.db")
dbLoadRecords("$(MOTOR)/db/motorUtil.db", "P=SMTR1608-9-B20-05:")
# cards (total controllers)
XPSSetup(1)
# card, IP, PORT, number of axes, active poll period (ms), idle poll period (ms)
XPSConfig(0, "192.168.0.254", 5001, 1, 10, 5000)
# asyn port, driverType, box number, number of  axes)
drvAsynMotorConfigure("XPS1", "motorXPS", 0, 1)
XPSInterpose("XPS1")
# Turns off the ability of the motor record to change an actuator's position without moving it.
XPSEnableSetPosition(0)
# card,  axis, postioner name, steps per unit
XPSConfigAxis(0,0,"S.Pos",10000)
asynSetTraceMask("XPS1",0,0x9)
#asynSetTraceMask("XPS1",0,255)
asynSetTraceIOMask("XPS1",0,0x2)
#asynSetTraceIOMask("XPS1",0,2)
iocInit()
Here is how my motor record and the XPS_extra records are defined.  In addition I have some additional PV’s defined to calculate the ultimate position of the motor.
record(motor,"SMTR1608-9-B20-05:brag")
                field(DESC,"Mono Brag")
                field(DTYP,"asynMotor")
                field(DIR,"Pos")
                field(VELO,"1")
                field(VBAS,".1")
                field(ACCL,".2")
                field(BDST,"0")
                field(BVEL,"1")
                field(BACC,".2")
                field(OUT,"@asyn(XPS1,0)")
                field(MRES,"0.0001")
                field(PREC,"5")
                field(EGU,"degrees")
                field(DHLM,"59")
                field(DLLM,"1")
                field(INIT,"")
                field(RTRY,"0")
                field(TWV,"1")
# Database for Newport XPS
grecord(ao,"SMTR1608-9-B20-05:brag:MIN_JERK_TIME") {
    field(DESC,"Min jerk time")
    field(PREC,"3")
    field(VAL,".01")
    field(DTYP, "asynFloat64")
    field(OUT,"@asyn(XPS1,0)MIN_JERK_TIME")
grecord(ao,"SMTR1608-9-B20-05:brag:MAX_JERK_TIME") {
    field(DESC,"Max jerk time")
    field(PREC,"3")
    field(VAL,".03")
    field(OUT,"@asyn(XPS1,0)MAX_JERK_TIME")
grecord(ai,"SMTR1608-9-B20-05:brag:READBACK") {
    field(DESC,"Readback")
    field(PREC,"4")
    field(PINI, "1")
    field(SCAN, "I/O Intr")
    field(INP,"@asyn(XPS1,0)MOTOR_POSITION")
grecord(ai,"SMTR1608-9-B20-05:brag:XPS_STATUS") {
    field(DESC,"XPS Group Status")
    field(DTYP, "asynInt32")
    field(PINI, "1")
    field(PREC,"0")
    field(INP,"@asyn(XPS1,0)XPS_STATUS")
I did an asyn trace and after starting up the motor records appears to be passing in the wrong values for the limits.
2013/11/01 14:03:31.880 motorAxisSetDouble[0,0]: error performing PositionerUserTravelLimitsSet for high limit=0.000000, status=-17
2013/11/01 14:03:31.888 drvMotorAsyn::writeFloat64, reason=4, value=0.000000
2013/11/01 14:03:31.895 devMotorAsyn::asynCallback: SMTR1608-9-B20-05:brag pasyn{Float64,Int32}->write returned
2013/11/01 14:03:31.904 motorAxisSetDouble[0,0]: error performing PositionerUserTravelLimitsSet for low limit=0.000000, status=-17
Upon initialization I am pushing in a movement from the home position of 6.000 to 8.54439294393059, however the motor is passing in a value below the low limit for an absolute move and is therefore not moving.
2013/11/01 14:03:36.041 SendAndReceive unexpected response =-17,GroupMoveAbsolute (S.Pos,1.398175069718e-312),EndOfAPI
epics> dbpr SMTR1608-9-B20-05:brag 10
ACCL: 0.2           ACKS: NO_ALARM      ACKT: YES           ADEL: 0
ALST: 0             ASG:                ASP: (nil)          ATHM: 0
BACC: 0.2           BDST: 0             BKPT: 00            BVEL: 1
CARD: -1            CBAK: 0xa0db8       CDIR: 1             CNEN: Disable
DCOF: 0             DESC: Mono Brag     DHLM: 59
DIFF: 2.54329294393059                  DINP:CONSTANT       DIR: Pos
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
DLLM: 1             DLY: 0              DMOV: 1             DOL:CONSTANT
DPVT: 0xa0dd0       DRBV: 6.0011        DSET: 0x40109680    DTYP: asynMotor
DVAL: 8.54439294393059                  EGU: degrees        ERES: 1.0e-04
EVNT: 0             FLNK:CONSTANT 0     FOF: 0              FOFF: Variable
FRAC: 1             HHSV: NO_ALARM      HIGH: 0             HIHI: 0
HLM: 59             HLS: 0              HLSV: NO_ALARM      HOMF: 0
HOMR: 0             HOPR: 0             HSV: NO_ALARM       HVEL: 0.1
ICOF: 0             INIT:               JAR: 5              JOGF: 0
JOGR: 0             JVEL: 1             LCNT: 0
LDVL: 8.54439294393059                  LLM: 1              LLS: 0
LLSV: NO_ALARM      LOCK: NO            LOLO: 0             LOPR: 0
LOW: 0              LRLV: 0             LRVL: 85444         LSET: 0xa18f8
LSPG: Go            LSV: NO_ALARM       LVAL: 8.54439294393059
LVIO: 0             MDEL: 0             MIP: 0              MISS: 0
MLIS: 00 0d 84 38 00 0d 82 f8 00 00 00 04                   MLOK: 00 09 e1 10
MLST: 0             MMAP: 0             MOVN: 0             MRES: 1.0e-04
MSTA: 2050          NAME: SMTR1608-9-B20-05:brag            NMAP: 0
NSEV: NO_ALARM      NSTA: NO_ALARM      NTM: YES            NTMF: 2
OFF: 0              OMSL: supervisory   OUT:INST_IO @asyn(XPS1,0)
PACT: 0             PCOF: 0             PHAS: 0             PINI: NO
POST:               PP: 0               PPN: (nil)          PPNR: (nil)
PREC: 5             PREM:               PRIO: LOW           PROC: 0
PUTF: 0             RBV: 6.0011         RCNT: 0             RDBD: 1.0e-04
RDBL:CONSTANT       RDES: 0x651d0       RDIF: 25433         REP: 60011
RHLS: 0             RINP:CONSTANT       RLLS: 0             RLNK:CONSTANT
RLV: 0              RMOD: Default       RMP: 60011          RPRO: 0
RRBV: 60011         RRES: 0             RSET: 0x40109488    RTRY: 0
RVAL: 85444         RVEL: 0             S: 50               SBAK: 50
SBAS: 5             SCAN: Passive       SDIS:CONSTANT       SET: Use
SEVR: NO_ALARM      SMAX: 0             SPMG: Go            SPVT: (nil)
SREV: 200           SSET: 0             STAT: NO_ALARM      STOO:CONSTANT
STOP: 0             STUP: OFF           SUSE: 0             SYNC: 0
TDIR: 0             TIME: 2013-11-01 14:04:06.363958000     TPRO: 0
TSE: 0              TSEL:CONSTANT       TWF: 0              TWR: 0
TWV: 1              UDF: 0              UEIP: No            UREV: 0.02
URIP: No            VAL: 8.54439294393059                   VBAS: 0.1
VELO: 1             VERS: 6.5           VMAX: 0             VOF: 0
What is even stranger is that the velocity and acceleration are then set to values much smaller than then should be (e-312)
I am sure I must have something configured incorrectly.  At this point it appears that the problem is associated with something configured incorrectly with the motor record.  I would greatly appreciate any feedback or insight anyone can provide.
Tonia Batten, P.Eng
Control System Analyst
Canadian Light Source
44 Innovation Blvd.
Saskatoon, SK S7N 2V3
Tel:  306-657-3865
Email: [email protected]
RE: Newport XPS-Q8 and Motor Record - RV120HAHL stage Mark Rivers
Prev: Re: Epics getting started White, Greg
Next: RE: Newport XPS-Q8 and Motor Record - RV120HAHL stage Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
