Hi Emmanuel,
This was done by one of the companies that commercialized EPICS. Some work was required to get this done. One thing is to use a directory service to serve as a the directory so that you can directly connect to the channel. There were some other changes
- but I do not recall them. I can give you a contact that may help. They installed several telemetry systems running EPICS with this modification to Channel Access.
Bob
I am contemplating a project which requires wireless communication.
I would like to have telemetry information on a control station.
The network link specification is: range 1 mile at 250Kbps
Latency could definitely be an issue (measurement needed at this point)
I could potentially have several 250Kpbs links (not sure whether they can be 'trunked' together)
The remote device could run an IOC (I need something like a 'fast' sequencer for sure)
Between local OPI and remote IOC, I can use any communication protocol I want
Classic architecture:
local OPI ---- (CA over wireless) --- remote IOC
is there a way for an OPI to bypass the UDP discovery process and force connection to a specific IP addres/port?
Other possible architectures:
* mirroring of IOC
local OPI --- (CA)--- local IOC -----(CA over wireless?) ---- remote IOC
How can you mirror an IOC, PV to PV ? (PV names need not be the same)
* 2 processes with duplicate queries
local OPI ---(CA)--- local IOC ----(serial protocol over wireless) ---- controller to remote hardware
The remote IOC is independent from above and need to query the hardware as well
Maybe IPC could help reduce the number of 'real' queries?
* custom development (with Robot OS, aka ROS, or equivalent)
local OPI ---(CA)-- local IOC --- (serial protocol over wireless)--- non IOC software, i.e ROS
Make sense, but learning curve...
Any input?
Emmanuel
- Channel access over wireless? Emmanuel Mayssat
Re: Channel access over wireless? Ralph Lange
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
