Hi @ all, Thanks for the replies.I haven't heard of that before. I had a quick look so far, but I'm not really sure how this can help me, yet. But I'll investigate more later, because I found a different solution by now - but thanks anyway. ;-) I had another look at the available record types and found out that the selection record does the trick. For the selection record not existing pvs are zero, like a pv.STAT with status No_Alarm. So I exchanged my calc records with sel records and chose 'High Signal' in the SELM field. This way the pvs created by the sel record are zero as long as there is no alarm - in case there is one, the value of this STAT field and hence the pvs from the sel record are bigger than 0, and that's exactly what I wanted. 2013/10/30 Mooney, Tim M. <[email protected]>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
