Looking at devGtr.c's waveform device-support I find the following:
1) Execution of the driver's 'readMemory()' and 'readRawMemory()' operators
is delegated to a callback task which is kicked off by the ISR.
These operators pull data from the card to a memory buffer.
2)a) If the waveform has FTVL set to SHORT or LONG then the waveform's BPTR
is directly passed on to readMemory()/readRawMemory(), i.e., in the
context of the callback task data are copied from the board directly
into the waveform record.
b) If FTVL is set to another data type then readMemory/readRawMemory
deposit data into an intermediate buffer. During record processing
(waveform's 'read' devsup entry point) samples are copied and converted
from the intermediate buffer into the waveform record.
=> Scenario 1+2a is not thread-safe. The callback task does not
lock the waveform record while writing data into it. I.e., nothing
prevents
e.g., a CA client from reading a partially old and partially new
waveform.
Solution:
i) use an intermediate buffer also in case 2a
OR
ii) in case 2a call readMemory/readRawMemory() from the waveform's
'read' devsup entry
point rather than from a callback.
OR
iii) Use classical asynchronous record processing to read data into
the waveform
record. Even 2b) could then be delegated to a worker thread.
Drawback: The current way to process the 'autoRestart' record
which rearms
the digitizer after all waveforms are read is no longer possible.
A different
method must be implemented.
Clearly, i) is easiest and least invasive but introduces some extra
overhead.
- Till
RE: Labview EPICS server and client data types. Vaughn, Brian
Re: sequencer + streamdevice Christoph Burandt
<2013>
Re: merge multiple alarms Tito Körner
EPICS support for USB TMC (Test & Measurement Class) devices -- Release 1.0 Eric Norum
<2013>
