On 28.10.2013 22:41, Christoph Burandt wrote:
Hello again,
thank you all, for some first hints.
A bit more detailed information about my setup:
*debian linux (squeeze, amd64)
*EPICS packages installed from the repository at
http://epics.nsls2.bnl.gov/debian/ (EPICS 3.14.12.3)
*StreamDevice-2-6 (from psi website)
*Asyn 4-17
The active lines in the RELEASE file are:
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
SNCSEQ=$(EPICS_BASE)/../modules/soft/seq
EPICS_BASE=/usr/lib/epics
ASYN=/usr/local/src/support/asyn/trunk
The SNCSEQ line seems to point to nowhere (path doesn't exist), but it
definitively works for the pure sequencer IOC like this. (!??!)
sncExample.dbd contains one line:
registrar(sncExampleRegistrar)
And the dbd file containing the stream device support is as follows:
streamInclude.dbd
include "base.dbd"
include "stream.dbd"
include "asyn.dbd"
registrar(drvAsynIPPortRegisterCommands)
registrar(drvAsynSerialPortRegisterCommands)
As I gather these line here, I realize, streamInclude.dbd is nowhere
being referenced explicitly. Does it have some special status?
Greetings,
Christoph
Hi Christoph,
The Debian EPICS packages install under /usr/lib/epics.
So, if your setting of SNCSEQ points to nowhere, you probably have the
sequencer installed as part of the epics-synapps-dev package.
If you want to override stuff with locally compiled modules, specify
them as usual in the .../configure/RELEASE file, *before* the setting
for EPICS_BASE. (Else your application will continue to use the package
stuff in /usr/lib/epics. The order of lines in the RELEASE file is kept
in the setting of include paths etc.)
If some rules depend on SNCSEQ being set, set it. Either to
/usr/lib/epics, or to a locally installed version, or to any string (in
which case stuff is found in /usr/lib/epics).
Your application must include all .dbd files and registrar declarations
necessary for both the sequencer and streamDevice.
It also must link against all libraries for both the sequencer and
streamDevice.
streamInclude.dbd is the dbd-include file for the streamDevice sample
application. Do not include it. It just shows what the dbd-include of
your application should contain to use streamDevice.
Also note that the epics-synapps-dev package contains asyn as well as
streamDevice. Unless you have a good reason to use your own locally
compiled versions, I would strongly suggest to stick with the packaged
versions. Locally compiled versions are by definition not
dependency-controlled by the packaging system, so they work around the
strongest advantage of using a package manager in the first place. It is
easy to create unstable applications by updating locally compiled
modules and not completely recompiling and linking all applications that
use them.
HTH,
~Ralph
- Re: sequencer + streamdevice Christoph Burandt
RE: Labview EPICS server and client data types. kathryn.baker
merge multiple alarms Tito Körner
<2013>
RE: sequencer + streamdevice Emmanuel Mayssat
<2013>
