1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Labview EPICS server and client data types.
To: "Vaughn, Brian" <[email protected]>
Date: Mon, 28 Oct 2013 16:22:29 -0500
Hi Brian,
On 10/28/2013 03:56 PM, Vaughn, Brian wrote:
When configuring a Labview EPICS Server I/O Server, one is able to
select from more data types than are available when configuring a
Labview EPICS Server I/O Client. For example, you can create a
network-published shared variable with a data type: array of booleans,
and link it to an EPICS PV, but when trying to create a corresponding PV
in the client, there is no option for the data type: array of booleans.
The same situation exists for unsigned integers, etc.
I don't know anything about the LabView software you're asking about, but the underlying Channel Access protocol only supports a limited set of basic data types which probably map directly to the set you're asking about for your client. The CA set is documented here:
  http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#Channel
Note that there are no unsigned integer types in that list, nor a boolean one.
The IOC database software is in a similar position, it supports unsigned integer types, and has a standard method of converting those into types for the CA protocol to transport.
A CA client can request the value of any channel or put a value to any channel using any type it likes, and the server must attempt to convert the data to/from that type if it can. However that conversion takes place on the server, and it is usually better for each client to look at and use the channel's native type for CA requests since that reduces the load on the (shared) server. I'm guessing that's probably what the Auto data type does that you also mentioned, but as I said above I don't use LabView so I'm only speculating there.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Labview EPICS server and client data types. Vaughn, Brian
Prev: Labview EPICS server and client data types. Vaughn, Brian
Next: Re: sequencer + streamdevice Christoph Burandt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Labview EPICS server and client data types. kathryn.baker
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
