1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EPICS record time delay
To: Miroslav Mihaylov <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 28 Oct 2013 13:31:06 -0700
Do you have a pointer to the userAve record?
The compress record (circular buffer) which is part of the EPICS base can do exactly the same.
Emmanuel
To: [email protected]
Subject: Re: EPICS record time delay
Date: Sat, 26 Oct 2013 03:28:31 -0500
Hi Chris,
If you are scanning for the TEMP say 10Hz you can use userAve record
to average over the last 100 or so TEMP records and use that userAve record
for the calcout.
Re: EPICS record time delay Kevin Peterson
EPICS record time delay Chris Whiting
Re: EPICS record time delay Miroslav Mihaylov
Prev: RE: sequencer + streamdevice Emmanuel Mayssat
Next: Re: EPICS record time delay Kevin Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS record time delay Miroslav Mihaylov
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
