Hello,
I'm having trouble setting up an IOC which provides both, the sequencer
and the streamdevice support at the same time.
Using "makeBaseApp -t ioc" allowed me to setup basic IOCs that support
either the sequencer or the StreamDevice support. I therefore modified
the files
configure/RELEASE
iocApp/src/Makefile
accordingly.
I checked that the resulting IOCs are ok by typing "help" in the IOC
shell -> either the "seq" or the "drvAsynIPPortConfigure" will be part
of the list of supported commands. I could also execute the state
machine from "makeBaseApp -t example".
If I try to write a Makefile which combines both features, "make" does
not complain (as it seems to me). But "help" in the ioc shell tells me
that "seq" is not a known command.
Can anyone explain what goes wrong here?
(The iocApp/src/Makefile of the "combined" IOC is attached)
Greetings,
Christoph
M.Sc. Phys. Christoph Burandt
Technische Universität Darmstadt
TOP=../..
include $(TOP)/configure/CONFIG
# ADD MACRO DEFINITIONS AFTER THIS LINE
# Build the IOC support library
LIBRARY_IOC += streamSupport
# Link locally-provided code into the support library,
# rather than directly into the IOC application.
streamSupport_LIBS += $(EPICS_BASE_IOC_LIBS)
# Build the IOC application
PROD_IOC = stream
# stream.dbd will be created and installed
DBD += stream.dbd
# stream.dbd will be made up from these files:
stream_DBD += base.dbd
# stream_registerRecordDeviceDriver.cpp derives from stream.dbd
stream_SRCS += stream_registerRecordDeviceDriver.cpp
# Build the main IOC entry point on workstation OSs.
stream_SRCS_DEFAULT += streamMain.cpp
stream_SRCS_vxWorks += -nil-
# Add support from base/src/vxWorks if needed
#stream_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
# Link in the code from the support library
stream_LIBS += streamSupport
# NOTE: To build SNL programs, SNCSEQ must be defined
# in the <top>/configure/RELEASE file
ifneq ($(SNCSEQ),)
# Build sncExample into streamSupport
sncExample_SNCFLAGS += +r
stream_DBD += sncExample.dbd
streamSupport_SRCS += sncExample.stt
streamSupport_LIBS += seq pv
stream_LIBS += seq pv
# Build sncProgram as a standalone program
PROD_HOST += sncProgram
sncProgram_SNCFLAGS += +m
sncProgram_SRCS += sncProgram.st
sncProgram_LIBS += seq pv
sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
endif
# Finally link to the EPICS Base libraries
stream_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
# ADD RULES AFTER THIS LINE
PROD_LIBS += stream
PROD_LIBS += asyn
- Re: sequencer + streamdevice Andrew Johnson
- RE: sequencer + streamdevice Emmanuel Mayssat
Re: EPICS record time delay Dirk Zimoch
Re: dbGetLink with options Andrew Johnson
<2013>
<2013>
