On 16.10.2013 10:32, Mi Qingru wrote:
> Hi,
> The problem has ocuured during loading munch as apachment showing.
> The vxWorks is 5.5. The Linux is Scientist Linux4.4. The base is
> 3.14.12.3. And the aysn is 4.21 and the motor is 6-7-1.
> Mi Qingru
If you need to set sysCplusEnable=1, there is probably something wrong
with your C++ setup. The file usrExtra.c contains:
#if defined (INCLUDE_CPLUS) || defined (INCLUDE_CPLUS_MIN)
BOOL sysCplusEnable = TRUE; /* TRUE = enable C++ support */
#else
BOOL sysCplusEnable = FALSE;
#endif
So if you build vxWorks with C++, the variable should already be 1.
Dirk
- Re: Problem as loading munch to vxWorks/mvme5500 Mi Qingru
- Problem as loading munch to vxWorks/mvme5500 Mi Qingru
Re: Problem as loading munch to vxWorks/mvme5500 Dirk Zimoch
asynError IOC message Vikram Bhagat
<2013>
<2013>
